Hot cam specs
Old Nov 17, 2006 | 06:17 AM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Default Hot cam specs
I did a search and didnt find the timing specs on the hot cam for the LT series. Does any one have the timing specs on this? I need this for some research I am doing. Thanks in advance!
Old Nov 17, 2006 | 08:05 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Have a look here mate: http://www.grandsportregistry.com/lt1vslt4.htm#CAM
The LT4 Hot cam is:
Part # 24502586
Duration: 218 226
Lift with 1.5:1 rockers: .492 .492
Lift with 1.6:1 rockers: .525 .525
Lobe: 112
Taken from http://www.malcams.com/legacy/misc/CamData.htm
Old Nov 17, 2006 | 10:48 AM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
The LT4 Hot cam is:
Part # 24502586
Duration: 218 226
Lobe: 112
Hey Case!!! hows it going!!!! What I am looking for is the valve timing tag info, this helps!
Old Nov 17, 2006 | 01:08 PM
Casethecorvetteman
Yeah im not too bad thanks mate, how have you been? I had a quick look for the timing wheel info but i couldnt find it.
P.S. Nice location you have listed there mate
Old Nov 18, 2006 | 08:45 AM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
TTT no one has the timing tag?
To Hot cam specs
