cam
Old Nov 17, 2006 | 08:56 PM
u c brother's Avatar
u c brother
Default cam
Hi I'm in the market for a cam for my 86 and would like to know if this cam will work. Lunati 270/280 204/214@0.50 .420intake/.442 exhaust.
Old Nov 17, 2006 | 08:57 PM
Pete K's Avatar
Pete K
Yes it will
Old Nov 17, 2006 | 09:02 PM
u c brother
Thank for the quick reply. Will it be loopy?
u c brother
Thank for the quick reply. Will it be loppy
Old Nov 17, 2006 | 09:03 PM
Pete K's Avatar
Pete K
What is the lobe seperation?
Old Nov 17, 2006 | 09:32 PM
u c brother
sorry the separation is 112.
Old Nov 17, 2006 | 09:36 PM
Pete K's Avatar
Pete K
That will be a little lumpy. Not radical though.
Old Nov 17, 2006 | 09:51 PM
u c brother
Thanks for the help.
Old Nov 18, 2006 | 01:08 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default cam
did you buy the cam yet? summit racing has a cam with lifters for the iron '86
Old Nov 18, 2006 | 07:24 AM
u c brother
No but I'll check with summit first. Thanks
Old Nov 18, 2006 | 12:48 PM
JAKE's Avatar
JAKE
Actually, I believe it won't be a whole lot different than the stock cam.
Other than the slightly extended exhaust duration it seems to be really mild and the valve lift is nothing to write home about.
Those specs are pretty close to the stock LT1 and LT4 cams, but the Lunati doesn't have quite as much valve lift.
If you're looking for a nice performance boost, start looking in the area just above 210 @ .050.
Cams with 20x @ .050 are stock-type stuff.
Just my thoughts.
Jake
Old Nov 18, 2006 | 07:15 PM
u c brother
Thanks Jake I want A little more than stock.
Old Nov 18, 2006 | 10:06 PM
86Pacecar's Avatar
86Pacecar
I'm running a Comp Cams Extreem Energy XE262H in my 86. With longtubes it ran a best 13.5 with 13.6 all day long. Going to get a custom tune and hopefully improve those times and clean up the idle some.
Old Nov 18, 2006 | 10:10 PM
lefoy84's Avatar
lefoy84
Look at the Crane 114132.
Old Nov 18, 2006 | 10:40 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
A nice cam and works with the stock set up very well.Its stock computer
friendly but every TPI with a mild cam and work can always benefit from a custom tune.There IS a difference in the way the midrange power band pulls over stock,it pulls harder and keeps going.
Heres a link I found directly for it.I put this same cam in the L98 once and it ran great..it had a somewhat lopey idle(with exhaust mods) that a few people came up to me and asked me if there was a cam in there and said it sounded like it had something in it...usually gear heads notice it more than your average Joe...just another better than stock cam grind to consider,but I do hear the LPE spec grinds for the TPI are even better.
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 19, 2006 | 02:06 AM
cv67's Avatar
cv67
St. Jude Donor '05
I like the profiles on the Lunati 256 Voodoo. Should work well with TPI and pass smog no problem. Reed makes a nice one also, very similar #'s, just a little more lift.
A recommendation from Reed...
210/217 @ .050, .470/.480 lift, 112 lobe center.
reedcams@mindspring.com
These are flat tappets, by the way. Kind of smallish but should work well with the TPI system with minimal tuning.
Old Nov 19, 2006 | 03:36 AM
cv67's Avatar
cv67
St. Jude Donor '05
Part Number: 114132 Grind Number: POWERMAX 2040 (FORMERLY COM
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1981 1987 CHEVROLET 8 GREAT FOR 305 HO, PERFORMANCE 350 TRUCKS AND TPI-EQUIPPED 350 ENGINES. GOOD MID AND TOP END TORQUE AND HP. AXLE RATIOS OF 3.73 OR NUMERICALLY HIGHER REQUIRED. AUTO OR 5- SPEED MANUAL. MUST USE ADJ. FUEL PRESSURE REGULATOR. (50 STATE LEGAL IN 81-87 267-400, CARB EQUIPPED CARS ONLY. C.A.R.B. E.O. D-225-25) BASIC RPM 2000-5000
Engine Size Configuration
267-350 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 2934 @Valve 440 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 3027 @Valve 454
Rocker Arm Ratio 1.5
Cam Timing: --- @---
Lift: Opens Closes ADV Duration
Intake --- --- 270 °
Exhaust --- --- 276 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99848
Loads Closed 114 LBS @ 1.700 or 1 45/64
Open 303 LBS @ 1.270
Recommended RPM range with matching components
Minimum RPM 1600
Maximum RPM 5400
Valve Float 6000
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake (4) ATDC 34 ABDC 109 210 °
Exhaust 47 BBDC (11) BTDC 119 216 °
Remarks:
Crane Cams continuously improves and upgrades its cam designs. In some cases this may mean that two Crane Cams with the same part number may actually be different grinds. You must check the GRIND NUMBER stamped on the front of the camshaft and check it against the Grind Number near the top of the Spec Card. For more information on the finest available camshafts, valve train components, and automotive ignition products, visit your local Crane dealer or call the Crane Cams tech line at (386) 258-6174 or FAX (386) 258-6167
install instructions
To cam
Old Nov 19, 2006 | 09:34 PM
u c brother
Thanks I ordered the crane cam
Old Nov 20, 2006 | 12:37 PM
JAKE's Avatar
JAKE
Harvey Crane, in an interview that appeared in one of the magazines, even - himself - admitted that CompCams is the best cam company.
What higher recommendation could there be, when you consider the excellent products and reputation that Crane has.
Jake
Old Nov 20, 2006 | 12:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
Problem is Comp has different companies making cams for them, they have become a giant. I hope quality control is as high a priority as sales #s are there.
I have used Comp before, but in general I like to patronize the smaller companies.
