still no power help
Old Nov 18, 2006 | 09:33 AM
stophie's Avatar
stophie
Default still no power help
Well it took me 1.5 hrs to get my hood open after the drivers side latch broke to open the hood had to take off the left wheel and wheel well I have no power to my ignition on my 1984 vette the battery is good and the interior and headlights work but I get no dash or anything else. I checked the two fusible links right by the battery they are good were should I go from here need help please
Old Nov 18, 2006 | 09:56 AM
jfb's Avatar
jfb
I believe on the 84 that the dash gets power from a wire with a fusible link that comes off the starter motor large bolt that the + battery cable goes to. Check for 12v on the starter bolt and using a pin, see if you have 12v before and after the fusible link.
