Rear Caliper
Old Nov 23, 2006 | 08:25 PM
lefoy84's Avatar
lefoy84
I could be wrong, but I think all 88-96 rear brakes are identical.
Old Nov 24, 2006 | 07:38 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
Default Thanks guys!
For the input on the deal with the GS stuff. I guess I'll just rebuild my J55's for now. Save the coin as them GS calipers are a bit pricey...sure do look cool though! Maybe after I fix all the important stuff I'll have some $ left over for some bling someday. Maybe this time I buy those PowerBrute sloted & drilled rotors and call it a day.
Again thank you Larryfs, Sidney004 & Lefoy84....it is truly the people and not so much the car!
Tom
Old Dec 6, 2006 | 10:01 PM
larryfs's Avatar
larryfs
any hints on using the ecklers caliper kit??
Do you assemble the tin pieces first into an assembly with the seal, or build it from the caliper housing first, and build outwards??
I can't see how that middle rubber seal will push into the caliper housing with the assembly connected.
Old Dec 6, 2006 | 10:05 PM
larryfs's Avatar
larryfs
also, was the kit suppose to come with the 2 little side springs??
it seems those 2 little side springs pull back on the assembly.
Mine are pretty stretched out and did not come with the kit..
