O2 Sensor
Old Nov 22, 2006 | 01:05 PM
lefoy84's Avatar
lefoy84
Default O2 Sensor
Looks like I have a bad one on my 96 LT4.
1. Who makes the OEM ones?
2. Where is a good place to buy them?
Old Nov 22, 2006 | 02:55 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I have Bosch and have had good look with them over the years, though a few people have had problems with them. Just get a name brand at you local auto parts store and you will be fine.
Old Nov 22, 2006 | 03:01 PM
JJ 86's Avatar
JJ 86
I'm having issues with my O2's as well. I replaced the faulty on about 1000 miles ago with a bosch unit and now I'm having the same issues as before. The new O2 has crapped out in only 1000 miles if that. I just ordered a Denso O2 that will be here friday and hopefully end my O2 problems. I wouldn't recommend bosch as an alternative.
Old Nov 22, 2006 | 05:10 PM
lefoy84's Avatar
lefoy84
Dou have a part # for the Denso?
Old Nov 23, 2006 | 12:00 AM
JJ 86's Avatar
JJ 86
I'll check the reciept. Can't remember off the top of my head. I ordered them from autozone.
Old Nov 23, 2006 | 12:06 AM
Ttime's Avatar
Ttime
I like the NGK /NTK O2 sensor.
http://www.ngk.com/results_app.asp?p...4&AAIA=1041332
Old Nov 23, 2006 | 04:05 AM
tjwong's Avatar
tjwong
I use AC Delco exclusively, I have had issues with aftermarket sensors both with life spans and with proper fuel trims.
Old Nov 23, 2006 | 05:23 AM
RRT vette's Avatar
RRT vette
I am using a Bosch O2 sensor in my 86 and I have AC Delco's in my 95.
Check your local Chevy dealer.
Old Nov 24, 2006 | 02:34 PM
JJ 86's Avatar
JJ 86
The part # for the denso O2 sensor is 234-4012.
Old Nov 24, 2006 | 03:34 PM
ZBRA's Avatar
ZBRA
I bought new GM sensors from Fred Beans (forum supporting vendor). They were ~70 each.
I prefer OEM, but I have had good luck with Bosch too.
Old Nov 24, 2006 | 10:50 PM
95BLKVette's Avatar
95BLKVette
I've changed all in my 95.
Replaced with discounted Borg Warners I found on Ebay,,,,3 for $90
Only problem was the pas side one flamed out after 2,500 miles
Replaced with AC Delco from Rockauto.com (Excellent Pricing & service).
To O2 Sensor
