Need help installing my serp setup..
Old Nov 26, 2006 | 04:30 PM
86GoldProject's Avatar
86GoldProject
Default Need help installing my serp setup..
I'm in the process of putting an engine in my car and i'm not quite sure where all the brackets and accessories are suppose to go, anyone have pictures? I know where the diff accessories should be located somewhat but i need help bolting everything on.. anyone have some pics I could look at for a reference? Anything would be appreciated, thanks!
86GoldProject
also can I just bolt my water pump on or are any of the holes on it used for holding on brackets etc?
Old Nov 26, 2006 | 05:38 PM
lefoy84's Avatar
lefoy84
You need to give a bit more info. Is this engine a replacement L98?
Old Nov 26, 2006 | 05:39 PM
86GoldProject
ah sorry, yeah its an 86 so its a 350, not exactly an L98 but same principal, heads have accessory holes and such.
Old Nov 26, 2006 | 06:28 PM
Happydad's Avatar
Happydad
What Happened to th Orignal Engine ??... Is this a replacement??
Old Nov 26, 2006 | 08:24 PM
85blkrose's Avatar
85blkrose
i can feel your pain. just went through this with my motor in the spring. bolt up the pwr steering pump bracket first with the short bolt in the bottom and the alternator bracket bolts up outside of that and the air pump off that. all will come together for ya
Old Nov 27, 2006 | 01:14 PM
86GoldProject
no idea what happened to the origional engine.. got the car with some boxes of parts and an empty engine bay.. so can I bolt the water pump on first???
Old Nov 27, 2006 | 02:13 PM
CFI-EFI's Avatar
CFI-EFI
Yes, but you may have to swap some fasteners around before you get it right. Several of the water pump holes take double ended studs and it would be a miracle if you got them all in the right positions the first time. As near as I can tell, the bottom left (drivers side) hole takes a 1 3/4" long, 3/8" bolt. The left upper takes a 3/8"-16 x 2.73"/3/8"-16 x 1.32" stud. The illustration in my parts book doesn't show the right side fasteners and for quantity it simply says AR (as required). The bolts are unlisted, but there is no other stud size shown for the water pump. If you have a total of three, then the right side gets two of them.
RACE ON!!!
Old Nov 27, 2006 | 04:59 PM
lefoy84's Avatar
lefoy84
These will help with the waterpump.
Old Nov 28, 2006 | 09:06 PM
86GoldProject
thank you guys so much! the info and the visuals help a ton! Now if i can get a pic of the rest all bolted up im set!
To Need help installing my serp setup..
