Remove the engine block heater?
Old Dec 2, 2006 | 05:43 AM
Eike's Avatar
Eike
Default Remove the engine block heater option?
Hi,
a friend of mine has a '90 L98 with the engine block heater option. We don't need it and without the aluminum pipe under the oil pan it would be easier to remove and install the pan.
Can we just plug the port at the block?
Old Dec 2, 2006 | 08:10 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Are you referring to the Oil Cooler
If so, i don't see a problem
Old Dec 2, 2006 | 11:31 AM
c4cruiser's Avatar
c4cruiser
There was an engine block heater available (RPO K05) and I wonder if it was part of the metal tube that ran under the oil pan? The heater may have been standard for export cars or those shipped to areas with really cold climates like parts of Canada, Alaska, or northern Europe.
Old Dec 2, 2006 | 08:49 PM
VenkmanP's Avatar
VenkmanP
Originally Posted by Eike
Hi,
Pretty sure you're talking about the oil cooler. A block heater doesn't have hoses, it has wires.
If you use synthetic oil then removing the cooler is probably fine.
Old Dec 2, 2006 | 09:39 PM
mseven's Avatar
mseven
'90 L98 with the engine block heater option. We don't need it and without the aluminum pipe under the oil pan it would be easier to remove and install the pan. Can we just plug the port at the block?
On your 90 that alluminum line under the pan going to filter housing would be part of the oil cooler assembly. It can be removed, however your oil temps. will probably go up a few degrees. You would need to put a plug in the block (where the coolant line exists)and remove the'"y" part of the coolant line under the AC bracket. The lower oil filter assembly that has the coolant lines will then be removed by unscrewing the threaded tube that is used for the filter. That threaded tube would then be put directly into the block for the oil filter.
Old Dec 2, 2006 | 10:47 PM
tonymax2's Avatar
tonymax2
Somewhere or other I saw a pic of the engine block heater. It mounts in one of the core holes (commonaly called freeze plug holes) on the side of the block; left side I think. It is a U shaped heating element similiar to the type used in a standard home electric water heater bent into an L shape with the short leg near the base and the long leg is about 2". A heavy duty "zip cord" extends from the base and has a plug on the end of it, 3-prong I think. The wire was strapped to the diagonal brace between the frame rail and the firewall. I believe it said it was for temps of -20 F or below but didn't specify if it had a built in thermostat in it for automatic on-off operation.
Old Dec 4, 2006 | 02:25 AM
Eike's Avatar
Eike
[QUOTE=tonymax2]A block heater doesn't have hoses, it has wires.
[...] On your 90 that alluminum line under the pan going to filter housing would be part of the oil cooler assembly.QUOTE]
OK, so it is not the block heater ... but it isn't the oil cooler, too. I pulled the line and the rubber hose attached to it and there was water in it. I'll post a pic tomorrow ...
Old Dec 4, 2006 | 07:16 AM
smokeshow's Avatar
smokeshow
it is the oil cooler but it uses the the coolant to circulate threw a adapter that bolts on the oil filter pad between the block and oil filterthat how it cools the oil ,and the block heater is installed in a freeze plug ,it heats your antifreeze not your oil ,if i remember rite it is installed on the pass side on a vette and it is the same size as a freeze plug ,it duznt stick out ,its not big and all you have to do is remove the electrical cord if your not going to use it ,but it not any bigger then a stock freeze plug and to remove it would be a waste of time cuz then you have to drive in a new freeze plug and i don't see how you can swing a hammer in their to do it it rite and if you get it in it might leak so just leave it alone their is no point wat so ever to remove it
Old Dec 4, 2006 | 09:00 AM
zoro's Avatar
zoro
As everyone has said, it is your oil cooler. The hard line comes from the water pump and attaches above the oil filter then another line goes to the block.
If you remove it your oil will run hotter--probably 10* C or more.
Old Dec 4, 2006 | 11:13 AM
mseven's Avatar
mseven
it isn't the oil cooler, too. I pulled the line and the rubber hose attached to it and there was water in it. .
have you taken off the rad. cap....my guess is you will see water there too.
Old Dec 4, 2006 | 11:18 AM
KeyWestJack's Avatar
KeyWestJack
My recommendation is do not remove it. Atleast not unless you are going to add a replacement cooler.
Old Dec 4, 2006 | 06:36 PM
Grenkepr's Avatar
Grenkepr
To Remove the engine block heater?
