87 6 speed install
Old Dec 4, 2006 | 10:31 AM
ls1dave's Avatar
ls1dave
Default 87 6 speed install
Has anyone converted a 4+3 manual over to the 6 speed trans???? I have an 87 4+3 manual I would like to convert.Looking for info on what all is required.I have read that it's an easy swap,is this true?
Old Dec 4, 2006 | 11:32 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
No, it's not easy, but there are quite a few who have done it, so I'll give you a bump to the head of the line.
Old Dec 4, 2006 | 11:53 AM
cv67's Avatar
cv67
St. Jude Donor '05
Do a thread search on Central Coaster. His conversion came out real nice. Maybe you can benefit from the mistakes he made..
Old Dec 4, 2006 | 12:02 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
CC did the most comprehensive write up(s) on the swap, so definitely check that out. He also has a VERY detailed chart listing parts by model year, clutch components, bell housing measurements, etc.
I did the swap too, and it was no picnic. There are a few pitfalls. First thing to decide is what you plan on using for a flywheel (dual mass, your single mass, aluminum, etc) and hydraulic / clutch set up. Then go from there.
Old Dec 4, 2006 | 01:28 PM
ls1dave's Avatar
ls1dave
Thanks for the info guys......I appreciate it.Will do a search for CC.The easy swap just seemed to good to be true.
Old Dec 4, 2006 | 01:43 PM
ls1dave's Avatar
ls1dave
i have searched for central coaster with no luck. i must be doing something wrong!!
Old Dec 4, 2006 | 07:54 PM
Don in Vermont's Avatar
Don in Vermont
Default 6 speed swap
I tried the search feature and had no luck either. The search feature is not at all user friendly.
Old Dec 4, 2006 | 08:18 PM
cv67's Avatar
cv67
St. Jude Donor '05
Here...Gotta make sure the caps and spacing is on or the search wont give you waht you need.
http://forums.corvetteforum.com/member.php?u=33821
Old Dec 5, 2006 | 01:08 AM
ls1dave's Avatar
ls1dave
Got it.........thanks.
To 87 6 speed install
