well my vette is in pretty rough shape, my Dad gave it to me and so now I'm tryin to get her in tip top shape, the problem is im a moron with cars lol. I figure ill learn with her though. although im sure the engine has alot of problems i plan on working on that later. right now my real problem is that the back trunk lights stay on no matter what and about 50% of the time the other lights in the inside that do work(the left side door and the left floorboard area light) want turn off either, so basically right now i have the fuse pulled that runs all these things. My step Dad knows a little bit and told me that it was probrally a bad ground(i dont really know what that means), we took apart the back trunk area and unplugged where the wires met and nothing changed so where do i go from here??? wheres the bad ground gonna be?? thanks for helping out a noob thats new to the corvette family.even without a workin dash and no inside lights she will fly
When you say "trunk" lights, do you mean the lights right behind you head on the post between the window and the back hatch window? If so, there is a swich that is located at the rear of the hatch that turns these lights on when the hatch is open. The long round rod on the window hits this switch and turns off the lights by depressing the switch. You have have broken the fitting that holds the switch in place, therefore the rod never turns off the lights.
Check out the post "power door lock problem 85 coup". There is informatiion in that post that may also help.
And welcome to the FORUM! We do try and help each other out. Learn about the SEARCH function and how to use it. This will help you see what has happened to others and other advice.
yes the lights in the hatch. well actually get this when i push down that button they dont go off????? thanks for the input, any idea about the other interior lights? why they want go off? my Dads a lawyer and hes had diffrent mechanics pay him by doing work and when thats how they pay u they almos always do a crappy job.....
maybe this will help yall understand the character of the problem, its all very ghetto..... when im driving and I push on the breaks the door light and the floorboard light will sometimes flicker on and off.... lol very ghetto eyh?? does that narrow down the possibilities??? Agent your link doesnt work. how do i check the timers?? thanks in advance.
