Quick Fuel Pressure Question
Its been around a couple of workshops trying to fix a problem.
Was told it was running way rich at idle and wouldnt pull at any throttle. The last workshop tested the fuel pressure and decided to drop it to about 35 psi to drop idle richness but made driving worse.
Now I have it and am planning to up the pressure and give it a full tune.
Just wondering what idle pressure is normal and what is a good full load pressure. Am thinking high 40's to low 50's.psi
Motor has been worked a bit by the sound of it and std injectors.
Where are you from?
Going to have a play with it on the dyno this arvo to try and dial in some throttle response at least. I havent checked the timing yet either so thats first up because the last workshop said he didnt know what to set it at and just wound it back to 8 deg btdc. I'm willing to bet he didnt have aldl terminals grounded when he checked it.
From south west Vic, down near Warnambool 3 hours from Geelong.
cheers
Do you have a service manual for this vehicle?? If not you probably should get one even if its only a Haynes.
I say this because of your willingness to bet he didnt have the ALDL terminals grounded when he did the timing. There is no mension of this step in any service manual ive read, what it does say is that the EST connector must be unpluged before you do the checking and adjustment. Its a single wire on the left hand side of the engine somewhere. It could be anywhere if the car is converted to right hand drive, and im not certain but i believe the colour is tan with a black stripe on it.
Im in QLD, youre abit too far away to drive over there, so i cant loan you my service manual!!
I've just read this after having it on the dyno and had forgotten the different procedure for checking base timing. I have the moates emulator and it has a switch on it that you can select either normal mode, aldl dump mode or self diagnostic/backup mode. Setting to backup mode shorts pin A and B which bought timing back to around 0 - 2 deg so I wound it up to 8deg. That made a fair difference.
I went to run it up on the dyno and it leaned right out 17:1 plus, so wound up the fuel pressure back to 42-44psi. Idle was rich so leaned that out on the chip and then run it up on dyno mid to high 13:1's down low and into 11's up high so am in the ball park. Spent 1/2 hour on it and got it running better.
Will check it next time, maybe friday and compare the two timing check procedures and get back on here. This is job for a mate thing so it might take a few weeks of after hours work to fully sort.
BTW the early commodores (VN-VS) run the same computer basically and the pin A-B short is the procedure and wind dissy back to 10 deg.
Thanks for your help.
Set that to 8 and restarted, ran a bit smoother too.
Ran it up on the dyno again, pulled 156 kw (200hp)at wheels, up 10kw (13hp) from last run. Thats with the std timing curve from ABTT Bin. The first run last week barely made 120kw (156hp) at wheels.
It now pulls in O/D. so am now getting somewhere.
Next play is next week sometime.
Cheers
I think i remember you saying something about this car before in terms of a modded Edelbrock intake on it, i cant remember if it was the same car or not, or if that was all it had or more. I reckon you should be able to get about another 10 or 15 horses at least. (asuming its got a good exhaust on it)
Good that youve got it running better!!
