Door hinge adjustment?
Old Dec 9, 2006 | 06:12 PM
Kool88vette's Avatar
Kool88vette
Default Door hinge adjustment?
I've been told that my door hinge pins are worn. The doors are a little hard to close. Is there a way to adjust them or replace the hinge pins so the will shut like new?
Old Dec 9, 2006 | 07:08 PM
5pinball's Avatar
5pinball
replace pins and bushings. search for a nice writeup on it.
Old Dec 9, 2006 | 08:32 PM
Kool88vette
So is this something I can do? Can you just change the pins and bushings without removing the hinges? I did a search and couldn't find a good thread for this adjustment.
Old Dec 9, 2006 | 09:07 PM
chillcat's Avatar
chillcat
can the door hinge pins cause the doors not shut properly ??
I've had a problem with my driverside door NEVER shutting all the way unless I give the door a pretty hard push. But the door shuts fine if the window is not up all the way, its like if the glass is up all the way then its a problem...Can I get inside the door and adjust the door glass track somehow ? I have been in there quite awhile ago and replaced the window motor--then again, when I shut the door with the glass down some, the glass hits against something inside the door and is loud,
Old Dec 9, 2006 | 11:01 PM
Ttime's Avatar
Ttime
I had the same issue. I ordered my bushings and pins from one our supporting vendors. I had a lot of up and down play when the door was opened. Closes like it was when it was new
I'll try to find the nice how to on this.
Old Dec 9, 2006 | 11:06 PM
Ttime's Avatar
Ttime
Link that helped me
http://chiphead6.homestead.com/files/hinges/here.htm
Old Dec 10, 2006 | 02:03 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
I have the bloomington gold door repair doc on pdf if you need it, great info for alignment and repair... email me: vdaddio@comcast.net
Old Dec 10, 2006 | 08:06 AM
Kool88vette
Thanks great info. Did you remove the hinges to replace the pins and bushings? Also, I can't find the parts on Eckler's or Mid America. Where can I find them?
Old Dec 10, 2006 | 08:19 AM
5pinball's Avatar
5pinball
i got mine at dealer. i think any auto parts stor might sell them. you dont take hinge off. you sopport door and do one at atime. its been a long time since i did it,and, dont remember all the details. thats why i said do a search.
Old Dec 10, 2006 | 08:53 AM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
If you remove that lower fender you can get right to hinge. Do one at a time and reinstall before tackling other one. As i remember on my 84 you had to get inside door to hold a plate that is used on door side of bolts. Not a real hard job just takes patience. Theres a guy on ebay that sells the pins and bushing kit. Good luck.
Old Dec 10, 2006 | 03:08 PM
VenkmanP's Avatar
VenkmanP
Try adjusting them before replacing parts.
There are a couple of writeups on adjusting doors in the tech tips section.
Old Dec 10, 2006 | 03:23 PM
Kool88vette
I found the pins for $7.00 each and the bushings for $2.00 on the Corvette America website. With the info I got from the thread I should be able to do it myself. After 18 years of use my hinge pins and bushings are shot. Thanks to all. You saved me $$$$.
Old Dec 10, 2006 | 03:53 PM
ALLT4's Avatar
ALLT4
Hey, that's my write up. I'm glad to see someone actually use it.
This is a really rewarding job, after you get the bushings and pins replaced; adjusting the door is easy because there's no slop in the hinges. When you move the door up down in and out to adjust, you don't have to take into consideration "hinge slop" because there is none.
Like I said in the write up, adjusting your doors isn't complicated it just takes a lot of times adjusting this, moving the door this way or that way, closing it slowly, looking at things, and thinking about which way to adjust things. Use your geometry lessons, that's all it is.
Old Apr 30, 2011 | 11:52 AM
ALLT4's Avatar
ALLT4
Just wanted to supply an updated link here for the hinges.
http://www.personal.psu.edu/gls17/hinges/here.htm
Old Apr 30, 2011 | 03:33 PM
93VettePilot's Avatar
93VettePilot
It is an excellent write up. I really had to dig to find it though. Thanks for taking the time to help us fellow corvette enthusiasts out.
Old Apr 30, 2011 | 04:03 PM
T. Wayne Nelson's Avatar
T. Wayne Nelson
We got our hinges from Autozone, about $8 bucks. Replaced one hinge at a time. If you have a small angle grinder, once you have the hinge removed the use the grinder to chew off the extra metal on the pin. Drive it out. Put in new pin and bushing, repeat. Piece of cake
Old May 1, 2011 | 02:27 AM
93VettePilot
Zip Corvettes also has them.
Zip
To Door hinge adjustment?
