Hey guys,
I'm looking to buy some QA1s to put on over Christmas break. I thought I read somewhere that you needed a different shock if your vette was lowered.
I have the QA1s on my lowered Vette (about 1.5" lower in the front). You'll definitely want a different body for the front if you have lowered it quite a bit. The shock meant for stock ride height gave me about 0.25" of piston travel and bottomed constantly (on the hard-stop clip). The shock I exchanged for had a body that was 0.5" shorter, IIRC, giving me some travel back. They still bottom on large bumps or dips while ripping through the mountains, but it is very rare.
Well..that's pretty low!! I was talking .5-1(at most)" lowered. Where did you get your shocks? And what kind? Are they still QA1 Corvette "C" Series Adjustable Shocks?
They are the C-series adjustable. I got them from an authorized distributor in northern California, but i would have to go through my receipts to recall the vendor's name and the part number. I don't remember how low my Vette is since it has been on blocks for over a year now, but certainly 1-2" below stock... It was quite dramatic. You could call QA1 directly, tell them what you're doing and they will probably make the correct recommendation since they are good people there.
Hey guys,
I had the same questions/concerns when I got mine. I have an 88 which was lowered. I talked to a guy named Joel from Naake Suspension Specialists (916) 771-0109. He'll ask you to measure the distance between the lower shock T to the bottom of the lower bushing...mine was 12 1/8", so I went with the 63-82 Corvette Front Shock which was 1/2" shorter then the 88-96. I think he said that the piston travel for this shock was 11 7/8" to 12 3/4". I ended up buying the shocks from JEGS for $139.99 ea (free shipping)...here were the part numbers:
Fronts (63-82 Corvette) - TC1958P
Rear (88-96 Corvette) - TC3024P
I love the QA1's. The fact that you can adjust them is amazing. You can easily dial in any "ride" you prefer. You will be amazed at the range between the 1st and 12th click. The only complaint I had was the fit. Your going to need a sh** load of washers, so have them ready during the install so you don't have to go back and put them on later like I did.
Good Luck
I had the same questions/concerns when I got mine. I have an 88 which was lowered. I talked to a guy named Joel from Naake Suspension Specialists (916) 771-0109. He'll ask you to measure the distance between the lower shock T to the bottom of the lower bushing...mine was 12 1/8", so I went with the 63-82 Corvette Front Shock which was 1/2" shorter then the 88-96. I think he said that the piston travel for this shock was 11 7/8" to 12 3/4". I ended up buying te shocks from JEGS for $139.99 ea (free shipping)...here were the part numbers:
Good Luck
could you gove all of us some pics, maybe we will give it a try....
When I told him year and model and that I was planning on lowering it about 1" he first said the 88-96 SHOULD be fine. Then I told him about the people on the forum getting 63-82 front shock because of lack of travel and then he said...those would work also and give the extra travel back. In the end, he said either shock should work but he was not sure exactly if there would be any issues with the 63-82 shock. He did not think so.
So...with out my car being lower current...I can't measure anything accurately. I did measure what I have (from lower T to mount) and it was 13.5 on the driver’s side and 13 on the passenger side!! But I guess it was not the best driveway to test it on...I can only guess when I lower it, it will be around 12.125” and 12.25”.
I'm going to give it a couple more days and, unless someone gives some different replies...i'm going to get the 63-82 fronts and the 88-96 rears.
What washers do I need??
If your going to lower it, I'd go with the 63 - 82 Fronts. I haven't had any problems, nor have I "bottomed" or "topped" out .
Here are the pics of the washers that I needed. Up front, I used 1 on each side of the "T" (lower bolts) because the lip on the lower "T" was not as long as the stock Bilsteins. When the shock was centered between the 2 bolts, the "T" on the shock only made it to the center of each bolt. The washers just gave me more surface area to hold it down. (Hope that makes sense)
For the rears, I used 2 on each side of the eyelet to make up the slack. Without those 4 washers, the shock had play and would clunk side to side. Not sure if this will be the case for your year. If you notice, most companies sell shocks for 84-87, 88 and then 89-96. I'm not sure why 88's are singled out or what's different, so you might be fine w/out washers. (I'd pick them up anyway just in case) Anyway, I got the stainless steel washers from Home Depot.
I am in the process of the job right now and I was wondering did you reuse the stock upper shock bushings in front. The 63-82 shock bushings are considerbly smaller in diameter than the stock ones.
I bought mine from jegs. They wern't too bad 129 and free shipping but I would have ordered from thoes other guys if I had known if they would be cheaper.
Hey Jeff, I know we PM'd each other on the shocks, but I thought I would ask here so everyone benifits.
Since they recommend the front to be different lengths due to lowering, what about the rear shocks?
My car at 2700lbs....rides toooo stiff in the back on stock zr1 bilstiens....will the QA1's solve this...or is the stock C4 leaf spring just too stiff for the weight of the car...?
Just put a set on my lowered LT4, have the fronts set to 6 & the rears to 4 (per a tech I spoke with - "perfect settings for sprited street driving on a C4"). If I hit the track he said fronts to 8 rears to 6. These shocks are incredible...night & day difference in the feel of the car, esp. being lowered. Car feels planted w/ no float at all.
