dana 36 durability?
Old Dec 12, 2006 | 04:40 PM
bigwave71's Avatar
bigwave71
Default dana 36 durability?
anyone have any idea how much horsepower a dana 36 can take?
i know certain things can make a difference like age,abuse and so on but just a rough idea. does anyone have any stories to share about there rear blowing out and what kind of power were you putting down
Old Dec 12, 2006 | 04:44 PM
Gixster's Avatar
Gixster
I read this a few days ago in the FAQ that's stickied at the top.
"The maximum ratio that will fit in a D36 is a nominal 3.73. After that, your taking your rear ends life into your own hands. The D36 has a power limit of about 450hp... but it won't last long on the strip, even then..."
Hope it helps!
Old Dec 12, 2006 | 04:45 PM
vader86's Avatar
vader86
HP does not break things, torque does.
That said, there is not a concrete limit to what they can withstand. It may take 500 lb-ft for 10 years or 10 seconds, you just cant say.
What will break it is slicks, DR's put it on life support and it'll go anytime it wishes, but street use should let it survive quite awhile.
Old Dec 12, 2006 | 05:02 PM
bigwave71's Avatar
bigwave71
yea, a 3.73 is the biggest gear you can put in a d36 and some rebuilders wont even put that in there. zips corvette here in richmond said that a 3.73 gear puts to much strain on the housing and has a more liklyhood of cracking the housing. im only putting out 371 rwhp and 401rwft. i have the 3.54 in mine so it looks like i should be ok for now. anyone have any more stories or info?
Old Dec 12, 2006 | 05:13 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
Richmond sells a 3.75 gear for the Dana 36 so is that a really bad idea or is close enough to a 3.73 that it's close enough ??
Old Dec 12, 2006 | 06:23 PM
C409's Avatar
C409
Default Dana 36
The 3.75 gears are for the 2.59 carrier and the 3.73's are for the 3.07 carrier in the Dana 36 . I broke my 3.75 Richmonds doing a burnout at the local drag strip , that was with a set of Mickey Thompson drag radials . Every tooth on the pinion had cracked but none gave up and I was able to drive it home . I haven't had my car dynoed yet but it has a 409" small block TPI 11:1 compression 1.6 Roller rockers and a warm cam. The tranny is built and has a 2400rpm convertor . I have recently installed a Dana 44 3.45 ratio and haven't run it on the strip yet . The local track is 1/8th mile and my best time so far was 7.82 @ 85+ mph . I'm hoping the times won't change much with the different ratio.
Old Dec 12, 2006 | 07:16 PM
MTVette's Avatar
MTVette
My D36 was upgraded to 3.54 gears. After modding the engine and exhaust, the engine was putting out an (estimated) 385 hp. The differential died a horrible death while driving vigorously on the street with ordinary street tires. YMMV.
Old Dec 13, 2006 | 03:30 AM
bigwave71's Avatar
bigwave71
looks like im right at the edge. bought my rear from zips and they give a 2 year warranty so if it breaks i hope it does it within 2 years hehe.
Old Dec 13, 2006 | 06:38 AM
Mr X's Avatar
Mr X
Does anyone have any pictures of broken 36:s? So it's the casing that breaks first?
Old Dec 13, 2006 | 08:18 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Id think if you break it due to over loading it or using it for a purpose it wasnt designed for the warranty may be void.
Have a look here mate: http://www.joby.se/corvette/ JoBy is a forum member here and he has a couple pics of an almost dead DANA 36
Old Dec 13, 2006 | 10:14 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Here is my story...I went to a test n tune one night to practice on the tree...my only mods were long tubes, cut lid and 3:73 gears...I was running Sumitomo street tires all around...
On my first pass of the night I heard what sounded like a gunshot go off immediately after launch....I had a box full of nuetrals and pulled over to the side rail...
It turns out I reduced my spider gears to chicklets...I never got a short time for that run since I broke but I don't think I made it to 60' anyway...lol...back then my normal short time was around 1.96- 2.00...I was making right at 260 RWHP and 290 RWTQ...
I now have a Dana 44 out back with 3:73's in it...it took me about a month to find out I didn't like the 3:45's that came with the 44...I tell y'all this story so you will know it does not take a 1.60 or 70 short time to bust a 36...nor does it take slicks or DR's...nor does it take a lot of HP or TQ....all it takes is one "decent" hook....
Old Dec 13, 2006 | 10:40 AM
bogus's Avatar
bogus
the quote that Gixster posted was a compilation of several of us. We wanted a line that explained it in terms that most people would understand.... perhaps a little simplified, but the end is close. When dealing with a SBC, 450hp will have about the same number in torque. The damage can be done.
I will tweek the quote to include references to the use of slicks, which will **** up a D36 faster than fast.
Old Dec 13, 2006 | 03:04 PM
Carl Johansson's Avatar
Carl Johansson
We run dana 36's with both a 3.08 setup as well as a 3.73 setup. The c ar (a C-3 in this case) has 458 HP at the crank. We use it for roadracing all over the western US. We assumed 3 years ago that we would be upgrading to a 44 or a 9inch ford in short order - but so far - no hint of any problem - sooner or later it'll let go - but we will have alot of fun breaking it!
Carl Johansson
Old Dec 13, 2006 | 06:16 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
3:54s in a Dana 36 with a HD cover. 396 LT1, street tires, 3500 stall. If you're ever going to mod the engine, go ahead and up grade to the 44 now.
Old Dec 13, 2006 | 06:55 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I've been running a couple D36's in my turbo 355 six speed for several years. My thing is road course events, not quarter mile. I run sticky tires, but there's no clutch dumps, and I try to make my downshifts smooth. So far things have held up well, but I don't abuse it unnecessarily. YMMV.
Old Dec 14, 2006 | 03:44 AM
bigwave71's Avatar
bigwave71
good stories here. that guy joby has some seroius sheit there. lookin good.
Old Dec 22, 2006 | 09:52 PM
BigLee's Avatar
BigLee
my D36 with original 3.07`s has taken considerable abuse both on the street, and nearly 400 passes at the track, and produced many high 1.70`s-1.80`s 60 ft. times. still doing fine, as far as i can tell...
a friend of mine was wanting to change the 3.07 ratio in his D36 for something lower, only to find both carrier bearing caps broken near the bottom bolts... and i think he also had one spider gear tooth broken off as well... the strange thing was, the rear wasnt making any kind noises. neither of us were expecting to find any damage.
but his car had been driven just as hard as mine, and he was using drag radials. one difference, was that if he left the line with wheelspin, he would just stay on the throttle. often, the tires would abruptly hook, sending a violent shock through the chassis.
my car has done this a few times as well, but usually, if i spin at launch, i will release the throttle before the tires bite, and abort the pass, and just cruise down the track.
i suspect that spinning, then the tires suddenly grabbing, are probably what kills many of these rears, not just hooking well....
To dana 36 durability?
Old Dec 29, 2006 | 12:11 PM
IHRA221's Avatar
IHRA221
We run an '85 & '88, w/ both a 36 & 44 we have broken them both. I believe that when you do a bad burn out and do not hook up well ( come out of the hole sideways @ a 45 degree angle ) due to not enough water, this SEVERELY effects the spyder gears.
Old Dec 29, 2006 | 07:08 PM
Road Agent's Avatar
Road Agent
So! 500hp and 200ft torque would rock with the D36?
Old Dec 29, 2006 | 10:42 PM
Lichen's Avatar
Lichen
It's hard to believe that you would have 500 hp and only 200 ft-lbs of torque.
