Valve covers??
Old Dec 12, 2006 | 05:35 PM
Tikiman12's Avatar
Tikiman12
Default Valve covers??
This next week i want to pull my valve covers and repaint them b/c they are discolored and the paint is pealing off.
I've never pulled vavle covers off, how do i do it and what can i exspect to happen when i pull it?
Should i get new vavle cover gaskets?
This is on an 87 L98 with 99k miles.
thanx
Old Dec 12, 2006 | 05:42 PM
Staehling's Avatar
Staehling
thanx
I'm going to do this in the next few months as well.
Love to hear from people who've done it, but in the meantime read this:
http://www.corvettemagazine.com/2000...vr/valvep1.asp
Old Dec 12, 2006 | 06:08 PM
Tikiman12's Avatar
Tikiman12
o awesome read, thanx
has anyone done theirs in a color other then the steel look? any pictures of these?
i'm planning on useing a white
Old Dec 12, 2006 | 06:09 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I used the VC paint from MAM to paint mine; I used nearly two cans.
I first degreased them and then wet sanded off most of the old paint. After each coat I wet sanded with 220grit, no sanding of the final coat.
Our VCs are Mg and rather pitted so I used several coats to fill in the pits rather than trying to sand them out.
I bought two new groumets, one for each VC as the OEMs were hard as rocks.
Use only FelPro VC gaskets, available at AutoZone.
When you install the VCs do not over thighten the bolts.
Old Dec 12, 2006 | 06:10 PM
Raidmagic's Avatar
Raidmagic
I've removed my valve covers a number of times. Other than wiggiling them out of their hole it's a pretty straight forward deal. You have to remove the EGR tube that runs across the pass. side one and I have to back out the lower bolt that holds my smog pump just untill it goes into the bracket. It's a hassle but stick to it you'll get it.
One more thing the stock covers alot of times have bad casting flaws so be prepared to do some work on them to make them look good or just put another style on there.
I got these from a member here years ago, they came on a crate motor he bought for his car. You can get these in chrome for about $100.
Old Dec 12, 2006 | 08:22 PM
VetteVet86's Avatar
VetteVet86
I was going to do mine on my late '86, but after I got them removed and stripped, the castings were so poor, that I decided to get some aftermarket ones. Just bought a set of these from Jeg's for 129.99. They are also available from Summit for the same price.They are polished cast aluminum and look great!!! They also come with new stainless hardware. Quality is good and they are manufactured for GM by Proform (i.e., you can get them at a dealer, but will probably pay more).
http://store.summitracing.com/partde...5&autoview=sku
Old Dec 13, 2006 | 02:32 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Same here. I painted them once before, but they are worse off than before now
I was going to powdercoat them next time.
Old Dec 13, 2006 | 03:29 PM
alyle5864's Avatar
alyle5864
Banned Scam/Spammer
I recently took my VC's off of my '86 to be powder coated. The left side required backing out the bottom bolt on the air pump. The right side required unbolting the EGR tube from the manifold and pulling out of the way. Once these two items were done the covers came off with little trouble.
Here are my covers.
Old Dec 14, 2006 | 04:05 PM
Tikiman12's Avatar
Tikiman12
bump for anymore advise?
Old Dec 14, 2006 | 05:22 PM
B!@cK 86 V3tt3's Avatar
B!@cK 86 V3tt3
I went to Advance auto parts and bought chrome eddlebrock valve covers for 39.99. Fit/look pretty good. Yes get a new gasket. Cheap and easy way for me instead of repainting.
Old Dec 14, 2006 | 11:25 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Here is a pic of my old setup, yes, my vette is yellow
Old Dec 15, 2006 | 11:18 AM
AKS Racing's Avatar
AKS Racing
I blasted mine and painted with zinc chromate primer that seems to etch into the magnesium. I sanded between coats of primer, then painted with single stage automotive paint. It has held up well.
Aaron
Old Dec 15, 2006 | 02:11 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
You can try the original valve cover paint. Try Eckelrs or an Anodized paint of your choice. There are some great looking powder coated L98 engines in this tread. You can buy a powder coat system from Eastwood.
Old Dec 15, 2006 | 05:35 PM
Demonic85's Avatar
Demonic85
I hear high temp engine enamel paint works pretty well. I got some to try later on when I remove them.
Old Dec 15, 2006 | 05:52 PM
Staehling's Avatar
Staehling
That's what I'm planning on trying as well...
Old Dec 15, 2006 | 06:12 PM
bill mcdonald's Avatar
bill mcdonald
I stipped mine down to that wierd cover paint GM has on there and painted them with 1500 degree silver paint.
I turned on the bbq and let them sit in there on low heat for about 30 mins to cure the paint. then let them cool on there for another 30 mins.
if you dont cure the paint it will rub off leaving silver on whatever they touch using that high temp paint.
Later I stipped them to the metal and polished them to death. I found after running the car for a week they faded. I was going to try some clear coat to stop it, but I ditched the idea and went aftermarket so it matched my polished super ram and engine brackets.
here is a pic I took right before I tore the engine apart.
Old Dec 15, 2006 | 07:51 PM
Strick's Avatar
Strick
Mine is a 92 and it had magnesium covers that I sanded down to 1000 grit and then used mother's to buff. This is the results, but you have to keep after them.
To Valve covers??
Old Dec 16, 2006 | 01:11 AM
Z51L83's Avatar
Z51L83
i had the same problem on my 84 covers, the paint that they used was cracking, peeling, and fading... so i threw some cheap chromies on there, and put my stock ones in the garage, and finally got around to having them powdercoated silver, and just had the aircleaner done... i'm just waiting to put them back on the engine, but that probally will be about another 3 months before its warm enough to tackle the job
heres the pic of my powdercoated job
Old Dec 16, 2006 | 07:16 AM
FF1wms's Avatar
FF1wms
St. Jude Donor '11-'12-'13
I did mine when I installed my roller rockers. I painted them with black wrinkle paint, then sanded and polished ribs. Turned out pretty cool.
Old Dec 19, 2006 | 09:55 AM
rich0239's Avatar
rich0239
2nd Gear
Default valve covers 1991
My covers were stained bad so I started looking for NOS valve covers. The problem is that no one has the drivers side valve cover. Only the passenger side exists. I ordered two passenger side and they appear that they could be used interchangably Can they be switched? The other question I have is how is the corvette emblem on the drivers side attached? I thought it had threads and was screwed into the threaded hole on the cover but when I ordered a replacement from corvette central it had self stick adhesive on the back side? What gives??
