power antenna
Old Dec 13, 2006 | 08:28 AM
cruzin89's Avatar
cruzin89
Cruising
Default power antenna
The motor is running but the antenna stays in the up position. Anyone have a suggestion. Thanks
Old Dec 13, 2006 | 09:16 AM
rick lambert's Avatar
rick lambert
The ribbon attached to the mast is probably shot....what year?
Old Dec 13, 2006 | 01:49 PM
Jerris's Avatar
Jerris
The good news is that the motor is running so you only need to buy the replacement mast.
Old Dec 13, 2006 | 03:13 PM
romroc's Avatar
romroc
On a '95, anyone know where the antenna lead can be gotten to?
My antenna won't pull off. Is it still repairable?
Old Dec 13, 2006 | 08:46 PM
nyernga's Avatar
nyernga
And have two people to install it. Unless of course your arms can stretch from the ignition switch to the antenna.
Old Dec 14, 2006 | 08:21 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Broken ribbon
There are 2 styles of ribbons, the older C4 uses a nylon rod with a metal hook and the newer ones uses a gear type ribbon. If yours is the old style, which i believe it is, then you will have to remove the motor, open it up and replace the nylon rod and finial end. I got my mast repair kit from GM for around $20. Here is a little info from my 86 manual.
http://members.shaw.ca/agent86/Power%20Antenna.pdf
To power antenna
