Transmission problems need help
Old Dec 14, 2006 | 07:10 PM
FL87Z52's Avatar
FL87Z52
Default Transmission problems need help
I noticed that my trans. was running hot so I checked the fluid and noticed it smelled burnt. So, I had had the trans. flushed and the filter changed, but it still runs hot and the fluid smells burnt again. There is no other problems what could cause this. I want to fix this problem before it becomes a bigger problem. What could it be where do I start?????????
Old Dec 17, 2006 | 11:25 AM
FL87Z52's Avatar
FL87Z52
nobody has anything?
Old Dec 17, 2006 | 12:07 PM
Frizlefrak's Avatar
Frizlefrak
Are we talking standard or auto trans, and what year? Are we talking about the '87 in your profile?
Pete K is the resident transmission expert, and is quite helpful. You might drop him a PM.
But based upon personal experience, it sounds like the clutches are done for. Plan on a full rebuild. You say the fluid smells burnt....what color is it? In my case, the fluid turned kind of a chocolate brown and first gear started slipping badly.
Sorry, I know this probably wasn't what you wanted to hear.
Old Dec 17, 2006 | 01:42 PM
FL87Z52's Avatar
FL87Z52
It's an auto. The fluid was a brownish color before it was changed. No gears are slipping. When it was flush they said there wasn't any clutches material in the fluid.
Old Dec 17, 2006 | 02:04 PM
Pete K's Avatar
Pete K
Is the lock up working? No lock up will raise temps quite a bit. You could also try flushing the cooler to se if there is a blockage.
Old Dec 17, 2006 | 02:14 PM
FL87Z52's Avatar
FL87Z52
Are talking about the cooler in the the radiator?. I just replaced the radiator last month. When it was flushed they said they weren't sure if the convertor was locking up.
Old Dec 17, 2006 | 02:19 PM
FL87Z52's Avatar
FL87Z52
They also said they could install a 2400 stall torque converter for 425-450 does this sound like a good price. I know I'll have install a cooler also, but I'll do that myself because they said that it could be $500 plus because of all the work involved
Old Dec 17, 2006 | 02:25 PM
Pete K's Avatar
Pete K
http://forums.corvetteforum.com/show....php?t=1556907
This link will describe how to check lock up. If the converter is not locking up, troubleshoot it before swapping the conveter. Are they going to supply and install a torque converter for $450?.The place that build my converters charges me $300 for a lock up, custom stalled 12 inch converter. In my opinion, this is a fair price. You can spend more and you can spend less, but be sure you buy a quality converter if you decide to change it. B&M and TCI are 2 brands to avoid(in my opinion)
Old Dec 17, 2006 | 02:32 PM
FL87Z52's Avatar
FL87Z52
Thanks for the help. It's the owner of an Aamco that gave me that price
To Transmission problems need help
