Compression ratio recommendations...
Old Dec 19, 2006 | 06:31 PM
ZBRA's Avatar
ZBRA
Default Compression ratio recommendations...
I'm looking for compression ratio recommendations for a naturally aspirated 383 LT1, track only car. I will be running 93 octane in it.
1) How high can I go?
2) Any benefits of going higher/lower?
Old Dec 19, 2006 | 07:22 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
8.5 dynamic compression ratio seems to be the high end for pump gas, from what iv'e read.
Old Dec 19, 2006 | 07:48 PM
5abivt's Avatar
5abivt
what kind of track? if its road racing you'll be running hotter for longer so maxing the compression won't be fun if you get days with not so up-to-par gas especially in hot weather. I've seen high as 11.8 on the street and most I believe are around 11-11.5.
Old Dec 19, 2006 | 10:30 PM
ZBRA's Avatar
ZBRA
Originally Posted by Pryderei
what kind of track?
Road racing.
Old Dec 20, 2006 | 08:26 AM
AGENT 86's Avatar
AGENT 86
You need to be concerned with dynamic compression and not static compression. Your cam choice will tell you what you can get away with. My 10.5 static compression turns into 8.5 dynamic compression, with the cam i a running. Use one of the many free calculators on the net.
Old Dec 20, 2006 | 08:28 AM
AGENT 86's Avatar
AGENT 86
Here is some good reading
http://www.empirenet.com/pkelley2/DynamicCR.html
Old Dec 20, 2006 | 09:47 AM
ZBRA's Avatar
ZBRA
Originally Posted by AGENT 86
Old Dec 23, 2006 | 01:18 AM
No Go's Avatar
No Go
I've got 11.9 CR static, but have not computed a dynamic number.
My GM847 cam probably keeps it manageable...296/304 duration, etc.
Lots of road racing, pump gas only, 15,000 miles so far.
Old Dec 23, 2006 | 09:05 AM
AGENT 86's Avatar
AGENT 86
Yeah, that duration should keep your DCR in a safe place.
Old Dec 23, 2006 | 09:51 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Thanks for the link...
To Compression ratio recommendations...
