TPI Throttle Cable Bracket
Old Dec 23, 2006 | 06:52 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Default TPI Throttle Cable Bracket
Note: I am here from the C3 forum so keep it simple
I have a 1968 BBC that I am converting to port fuel injection using a custom made plenum (because of hood clearance issues) on a Ramjet intake. I have purchased a bored TPI 52mm throttle body for use with this conversion which I believe has a later "progressive" linkage. I may have my terminology wrong but it has a cam that the cable rides in with a small hole at the end to accept the throttle cable. Throttle bracket has the number 83321 and 83322 on it, Rochester Products.
My question is this. Will a throttle cable bracket from any TPI corvette work for me? Also, are all TPI throttle cables the same?
Old Dec 23, 2006 | 08:05 PM
JackDidley's Avatar
JackDidley
When they went to a progressive throttle body they changed the end of the cable where it attaches to it, so you will need a newer cable. That should be a super ride when its done. Good luck with your project.
Old Dec 24, 2006 | 01:33 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Im not sure what years,but I do know they changed the TB cable around 1990-91...my older 86 had the cables with metal tab with a hole at the end...youd slip them onto the TB and push a clip over it to hold into place.Didnt have the sliding feature the newer models had that youd slip the cable cam into a small hole to secure it.
That being said,the earlier TPI set ups didnt use the newer design.
Just dont know the exact years for sure,but wnated to point this out that the earlier units had a much different attachment.
Old Dec 24, 2006 | 09:24 AM
BBShark's Avatar
BBShark
Thanks, It looks like I can use a throttle cable bracket from 85-up and I will need a throttle cable from a 92? Is that the last year for the TPI?
Old Dec 24, 2006 | 10:20 AM
Hooked on Vettes's Avatar
Hooked on Vettes
85-88 used the same accelerator cable and mounting bracket.
89-91 used the same accelerator cable and mounting bracket.
91 was the last year for the L98/TPI.
The bracket also supports the cables for cruise control and the TV cable for the 700R4.
Old Dec 25, 2006 | 08:34 PM
BBShark's Avatar
BBShark
Thanks. I just ordered a 91 cable. Now all I have to hope for is that the cable length is good and will fit my accelerator pedal attachment! To all who responded, thanks again.
To TPI Throttle Cable Bracket
