sequential ??
Old Dec 25, 2006 | 08:01 PM
gator79's Avatar
gator79
Default sequential ??
I have a '93 how can I tell if it sequential injection?
Old Dec 25, 2006 | 08:02 PM
STL94LT1's Avatar
STL94LT1
It's not sequential, that started in 94.
Old Dec 25, 2006 | 08:14 PM
gator79's Avatar
gator79
i heard some late '93s were sequential
Old Dec 25, 2006 | 08:16 PM
STL94LT1's Avatar
STL94LT1
Check your fuel rails. I'm pretty sure all sequentials had a cross-over.
Old Dec 25, 2006 | 08:17 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I'm just taking a guess here, but supposedly some '93's came with the later style transmission(4L60E rather than the 4L60) in which case you would have the silver PCM rather than the black ECM, nobody has any concrete evidence that this is true, my guess is also it would have the MAF as well since that came in '94.
Also teh intake manifold would have a crossover tube.
But like I said, it's only a guess and probably wrong.
Old Dec 25, 2006 | 08:37 PM
gator79's Avatar
gator79
the '93 FSM states seqquential fuel injection vin J, what space would that be in the vin?
Old Dec 25, 2006 | 09:03 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
That would be a LT-5 (ZR-1) Eighth digit.
Old Dec 25, 2006 | 09:15 PM
gator79's Avatar
gator79
just checked my vin no J
I would know if I had a ZR1,I was just hoping for sequential injection. looks like mine is batch fired
Old Dec 25, 2006 | 09:32 PM
RRT vette's Avatar
RRT vette
I would say you have batch fire.
Old Dec 25, 2006 | 09:36 PM
STL94LT1's Avatar
STL94LT1
My 94 with SFI is VIN P.
Old Dec 25, 2006 | 09:43 PM
RRT vette's Avatar
RRT vette
So does my 95.
Old Dec 25, 2006 | 09:57 PM
gator79's Avatar
gator79
mine is vin P also, I was just going by the '93 FSM and it states vin J as sequential multiport but that must be the ZR1
Old Dec 25, 2006 | 10:03 PM
MikeC4's Avatar
MikeC4
What exactly is "batch" fire? I am sensing fuel in-efficiancy here...... I have a '93
Old Dec 25, 2006 | 10:13 PM
RRT vette's Avatar
RRT vette
Sequential (multi port)- each injector fires individually in firing sequence.
Batch - a bank/batch of injectors fire together (all injectors fire in one batch). One side fires then the other side.
Old Dec 25, 2006 | 11:15 PM
pcolt94's Avatar
pcolt94
My Tech 1 will not select SFI for a 93, only a 94 and up. The 93 comes up MFI.
What’s interesting is if I select the fuel system for a 94 by VIN number, it selects SFI . But if I select fuel manually by menu it comes up as MFI. Not sure if menu selection and operation is same for both, have never explored that difference. I always select by VIN, P, eighth digit
Old Dec 26, 2006 | 12:29 AM
comp's Avatar
comp
Old Dec 26, 2006 | 02:33 AM
tjwong's Avatar
tjwong
All 92 and 93 Y and 93 F body used the same ECM and they are both batch fire. SEFI was not introduced until the PCM hardware change in 1994. Also in 1994 the MAF sensor returned for better emissions control. The only basic difference between the older speed density batch fire cars was that they didn't have the more precise fuel control of the MAF strategy cars. However performance numbers and power ratings were basically the same. There really isn't any significant power gains between the two strategies. The main benefit is that SEFI offers some more tunability as one can trim fuel to individual cylinders. So that means it can offer slightly better tuning abilities when larger cams are used. A MAF strategy is also a bit more forgiving with engine mods. Which means tuning one is a bit easier than a SD car. But that ends if a very large cam is installed.
To sequential ??
Old Dec 26, 2006 | 12:14 PM
zr1fred's Avatar
zr1fred
GREAT explanation!
Old Dec 26, 2006 | 12:16 PM
Casethecorvetteman's Avatar
Casethecorvetteman
It is. The LT5 in the ZR1 has SEFI. Your 93 LT1 does not. No late 93s had SEFI or 4L60-Es, they were early 94s.
For every one person that says late 93 cars had the 4L60-E, there is another 1 that says the first run of 94s only had 4L60s. Neither one of them can prove either statement to be a fact.
Old Dec 26, 2006 | 01:01 PM
bogus's Avatar
bogus
The real advantage to SFI is economy. The MPFI maxes at about 26mpg highway, whereas the SFI will top 30 on the highway.
