hei help
Old Dec 25, 2006 | 10:11 PM
smfspeedemon's Avatar
smfspeedemon
Default hei help
i have a 1988 corvette coupe and i just put a 440hp motor in it along with a hooper rearend with 433 gears and a tci 2800 stall con. here is my problem somehow when we put the motor in we crimped of the leads for the hie i found the pink wire but cannot find the tach wire i need that for my msd does anyone know were that wire oginiates so i can run a new one or how to find the old one meter it is it indeed white im going crazy thank you and merry xmas
Old Dec 25, 2006 | 10:16 PM
RRT vette's Avatar
RRT vette
The tach wire is white. It connect to the distrubitor (TACH), then the tach filter, and connects to another connector... then disappears in the firewall
Old Dec 25, 2006 | 10:28 PM
SunCr's Avatar
SunCr
Runs through the Big Connector behind the Battery to Pin C5 at the Cluster. For '88 it should be in Cavity E1 at the Connector which should be the 3rd row down from the top, right side. This is the Cluster Signal only. I'd think your ignition would work without it, but then you wouldn't have a display. ECM ignition is a 4 wire harness and the EST signal is a white wire to PIN D4 at the ECM. It runs through the right side of the Firewall, behind the head.
Old Dec 25, 2006 | 11:11 PM
smfspeedemon
is that tach filter silver and looks like a barrel about the size of a 1/4"drive9/16 socket?
Old Dec 25, 2006 | 11:13 PM
RRT vette's Avatar
RRT vette
Description sounds right. Wrapped in a metal holder with a place for a bolt.
Old Dec 25, 2006 | 11:15 PM
smfspeedemon
when you say pin 4 your talking about the brain correct?
Old Dec 25, 2006 | 11:18 PM
smfspeedemon
Decsription sounds right. Wrapped in a metal holder with a place for a bolt.
its bolted to my block wich grounds it is that supposed to be grounded? i found that if thats the wire and its suppossed to be grounded than im good to go thank you verry much for your help
Old Dec 25, 2006 | 11:19 PM
RRT vette's Avatar
RRT vette
That is the terminal I.D. at the ECM connection. You will need a FSM to locate it's exact location.
Yes, the tach filter should be grounded. Either on the left rear cylinder head or on the left side bell housing. Some members report that the tach filter is mounted in either location. Mine is on the head.
To hei help
