Weight Reduction (who has the lightest engine)
Old Dec 28, 2006 | 10:09 PM
NitrousSam's Avatar
NitrousSam
Default Weight Reduction (who has the lightest engine)
This is a little different thread about weight reduction because I want to focus directly on the engine. What you have done to reduce weight to your C4 engine? I am sure most people have not weighed their engines but those of you who have been concerned about reducing pounds may have found something I have overlooked. If you have any ideas about reducing engine weight I would love to hear from you with your ideas, tips and tricks.
Thanks,
NitrousSam
Old Dec 28, 2006 | 10:15 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Well right now, I have the intake and heads off, that reduced the weight a little bit!
Old Dec 28, 2006 | 10:16 PM
Mojave's Avatar
Mojave
I want to do an LSx swap on my 96. Aluminum block + plastic intake = teh lightness.
Old Dec 28, 2006 | 10:24 PM
Pete K's Avatar
Pete K
A friend of mine runs a low 6 second vette. Every piece in or on the engine is lightened. Even the an fittings are milled down to lighten the load. Car weighs 1850 lbs with him in it.
Old Dec 28, 2006 | 10:43 PM
NitrousSam's Avatar
NitrousSam
Is your friend a forum member? Can you share any further details about things he has done to cut weight? You have my attention because I am trying to build a 2500 lb C4 and I have tweaked most of the car and now it engine weight reduction time. I have the basics done to the engine but I know there are people who have gone to the extreme...I need some extreme tips and tricks.
Thanks,
Sam
Old Dec 28, 2006 | 10:46 PM
ZBRA's Avatar
ZBRA
Please share! If you have any pics, send them my way and I will host and post them.
Old Dec 28, 2006 | 10:50 PM
Pete K's Avatar
Pete K
He is not a forum member. He is the owner of Jensen Engine Tech in Nescopeck Pa.
His car is extreme. Carbon fiber body, tube chassis, and a 427 cube twin turbo small block making 2300 hp. Every time I look under the hood, I find something new. Even the back sides of the door handles are milled out on the bridgeport.
Old Dec 28, 2006 | 11:05 PM
LT4BUD's Avatar
LT4BUD
Thanks,
NitrousSam
I did the ATI damper....don't remember exact, but a couple of pounds....aluminum pulleys
The electric water pump is a tad lighter too
Valve train weight can be reduced a tad by careful selection of components..
Run the engine down one quart of oil.....2 pounds or so
Smaller size oil filter?????
Smaller coolant overflow....smaller radiator...
Alternator, power steering pumps(electric?).....
Old Dec 28, 2006 | 11:13 PM
danno85's Avatar
danno85
You need to talk to the guys that build sprint car engines. One shop in TX that has a CNC block lightening program is Wells Racing Engines
(www.wellsracing.com). Go to their web site and click on the "video" link and they have a video of their block lightening process.
Good luck,
Dan
Old Dec 28, 2006 | 11:34 PM
NitrousSam's Avatar
NitrousSam
If you can find any photos of this car that would be great. Weight reduction in my C4 has been a huge priority for me and it sounds like I can learn something from your friend.
NitrousSam
NitrousSam's Avatar
NitrousSam
Good stuff
Old Dec 29, 2006 | 12:09 AM
pablocruise's Avatar
pablocruise
For us cavemen that are stuck in GEN III technology, is there an aluminum block with a 1 piece rear main seal?
Old Dec 29, 2006 | 12:51 PM
Pete K's Avatar
Pete K
I think his website is www.jensenenginetech.com,
but I will double check. Pretty sure he has a photo gallery on the site. I will check.
Edit: link is wrong, don't click it. I will find out the correct one.
Old Dec 29, 2006 | 01:23 PM
BigLee's Avatar
BigLee
i managed to get 13 lbs out of my original 86E engine block, mainly using an angle grinder and drill.....
i also cut 3-4 lbs out of the original TPI manifold base as well, before i switched to a miniram.
last time i weighed my car, it was down to 3,040 lbs, curb weight with a bout 1/4 tank of fuel. still had the A/C, and original 16X9.5 wheels on it...
Old Dec 29, 2006 | 04:15 PM
Bruce Witherspoon's Avatar
Bruce Witherspoon
Thanks,
Sam
The car of mine that you have already seen only weighs 2700lbs and it has the stock power seats, speakers in the doors and all the lights are op[erational, even the horns.
Old Dec 29, 2006 | 05:28 PM
dizwiz24's Avatar
dizwiz24
Ok, thats great, but can you tell us what you did to get there?
Not what all you still have in it?
Old Dec 29, 2006 | 05:31 PM
Mr6spd's Avatar
Mr6spd
For a starting weight reference point, what does a stock TPI engine block weigh? I've seen figures between 142 and 180 lbs. What are they really?
To Weight Reduction (who has the lightest engine)
Old Dec 29, 2006 | 05:54 PM
Trog's Avatar
Trog
This is what I keep looking at & wondering if a streetable version could be built up?
http://www.cnblocks.com/splaysbc.htm
can we say and
Old Dec 29, 2006 | 07:49 PM
pablocruise
wow Trog, that is an amazing creation.
Doesn't say if they can do 1 pc. RMS.
They want a $4K deposit. Wonder what the balance would be
I wonder what is the lightest crank for us C4 vette dudes would be?
Old Dec 29, 2006 | 07:55 PM
Vic'89's Avatar
Vic'89
Wow, how did you get it so light?
Vic
