SYS reset
Old Jan 4, 2007 | 06:06 AM
95 blue pig's Avatar
95 blue pig
Default SYS reset
I have seen talk about the flashing SYS on the display, but I couldnt find any info on how to stop SYS from flashing. Can any one help? oh it is A 95 c4 auto. stock[almost]
Old Jan 4, 2007 | 06:35 AM
MARKSC4's Avatar
MARKSC4
Mine stopped flashing after I replaced the battery.
Old Jan 4, 2007 | 07:24 AM
runner140*'s Avatar
runner140*
To reset, disconnect the negative battery terminal for a minute.
Old Jan 4, 2007 | 07:37 AM
pcolt94's Avatar
pcolt94
With info so far. If this does not work, see if you can pull any codes that might indicate a problem. The SYS indication is mainly focused on the CCM operation.
For your piece of mind, I had the same thing happen to me when I first bought the car and knew nothing specific about the systems. I changed my battery to.
Lets hope for no codes and a battery might fix it.
Old Jan 5, 2007 | 04:54 AM
95 blue pig
I tried the battery disconect ,no good . I will try code reader. Thanks!!
Old Jan 5, 2007 | 06:32 PM
subman's Avatar
subman
Follow this link to Bogus's reply
http://forums.corvetteforum.com/show....php?t=1582153
c4guru-tells you how to pull codes from ccm.
Good luck!
To SYS reset
