I have a 1996 LT1 with a 4l60E that I need to find the wiring diagram for the transmission. Reason being is that it seems the transmission power wire has gotten pulled out or cut causing all the shift and converter clutch to not function . Or if anyone doesnt have a diagram i just need to know which firewall plug the power wire runs to so it can be repaired.
Check Pin E of the transmission connector. It is fed from a 10a fuse number 15 also marked "auto trans".
