MASS AIR FLOW code 33
Cheers,
Michael
If you send me an email (jgkov@msn.com) I'll photograph the trouble shooting pages from my '85 GM Shop Manual and return the pics to you.
Code 34= manifold air pressure (low).
yes check both Maf and Burn off midule whic located beside main ECM, its a rectangle shape small box with a pigtail wires.
Whatever trouble guide youre quoting is wrong if its for 85s.
Sorry here i copied this :
CODE 33
Trouble Code 33 indicates that the Mass Air Flow (MAF) sensor is reporting more air is entering the engine than makes sense based on RPM and TPS. The MAF sensor produces a frequency output; around 30 Hz at idle to 150 Hz under acceleration. The frequency varies proportionally to airflow. The ECM monitors the frequency and thus determines airflow into the engine. Typical idle MAF is 5 to 7 grams per second.
The conditions for setting this code are:
no Code 21 or 22 (TPS Error) present, and
the air flow reported is > 40 grams per second, and
TPS indicates < 10% throttle position, and
the engine speed is 1400 RPM or less, and
the above conditions exist for over 5 seconds.
Typical causes for this code include:
1) Faulty MAF-to-ECM connection
2) Exceedingly noisy spark plug wires
3) Poor routing of MAF harness (i.e. near coil packs)
4) Maladjusted TPS sensor
5) Defective MAF sensor
6) Defective ECM
Return to Chart
CODE 34
Trouble Code 34 indicates that the Mass Air Flow (MAF) sensor is reporting less air is entering the engine than makes sense based on RPM and TPS. The MAF sensor produces a frequency output; around 30 Hz at idle to 150 Hz under acceleration. The frequency varies proportionally to airflow. The ECM monitors the frequency and thus determines airflow into the engine. Typical idle MAF is 5 to 7 grams per second.
the air flow reported is < 4 grams per second, and
TPS indicates 10% or more throttle position, and
the engine speed is 1800 RPM or higher, and
1) Faulty air ducting to or from MAF sensor
2) Faulty ECM-to-MAF connections
6) Defective ECM
http://www.corvettedoctor.com/1985_91_DTC_Codes.html
Code #12: Normal No Codes.
Code #13: Open Oxygen Sensor Circuit.
Code #14: Coolant Sensor Circuit Low.
Code #15: Coolant Sensor Circuit High.
Code #21: Throttle Position Sensor High.
Code #22: Throttle Position Sensor Low.
Code #23: Manifold Air Temperature Circuit High.
Code #24: Vehicle Speed Sensor.
Code #25: Manifold Air Temperature Circuit Low.
Code #32: EGR System Failure.
Code #33: Mass Air Flow Sensor High.
Code #34: Mass Air Flow Sensor Low.
Code #36: Mas Air Flow Sensor Burn-Off Function Fault.
Code #41: Cylinder Select Error.
Code #42: Electronic Spark Timing.
Code #43: Electronic Spark Control.
Code #44: Lean Exhaust indication.
Code #45: Rich Exhaust Indication.
Code #46: Vehicle Anti Theft Fault.
Code #51: Faulty Mem-Cal.
Code #52: Fuel Calpak Missing.
Code #52: (1990-91 Corvette Only): Engine Oil Temperature Sensor Low.
Code #53: System Over Voltage.
Code #54: Fuel Pump Circuit Low Voltage.
Code #55: Defective ECM.
Code #62: Engine Oil Temperature Sensor Circuit High.
