84 TBI question
Old Jan 20, 2007 | 05:59 PM
  #41
C4Techie's Avatar
C4Techie
Originally Posted by VetNutJim
Will changing from a 2 barrel carb. to a 4 barrel carb have any effect on the dynamic compression of an engine?
What is "dynamic compression"? Are you referring to the dynamic compression RATIO of an engine? If so, then NO!. The static compression ratio is the comparison of the cylinder volumes, with the piston at TDC and the piston at BDC. The dynamic compression ratio is a similar comparison of volumes; however, instead of comparing TDC volume to the full, BDC cylinder volume, it is only comparing it to the effective cylinder volume, after the intake valve closes, where compression can actually begin. The comparison of measured physical volumes is not effected by types of induction. Volumetric efficiency (VE) is another topic of discussion.
Old Jan 20, 2007 | 06:59 PM
  #42
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The calculated compression ratio (refered to as "static compression"), presumes that the cylinder is sealed at the bottom of the stroke (BDC or bottom dead center), and that the volume compressed is the actual volume.
This is not true: intake valve closure (sealing the cylinder) always takes place after BDC, which causes some of the intake charge to be compressed backwards out of the cylinder by the rising piston at very low speeds; only the percentage of the stroke after intake valve closure is compressed. This "corrected" compression ratio is commonly called the "dynamic compression ratio".
This is also why larger duration cams not only allow, but require more static compression; they "leak" more if the compression back in to the intake than a shorter duration cam.
Old Jan 21, 2007 | 02:16 PM
  #43
C4Techie's Avatar
C4Techie
The compression ratios are a numerical comparison of volumes. Whether the cylinders are sealed or not, makes no difference. The compression ratio ("the volume compressed is the actual volume.") doesn't take into account anything actually being compressed. It is (as a ratio is by definition) simply a numerical comparison of the cylinder volumes with the piston in each of two different positions.
This is not true: intake valve closure (sealing the cylinder) always takes place after BCD, which causes some of the intake charge to be compressed backwards out of the cylinder by the rising piston at very low speeds; only the percentage of the stroke after intake valve closure is compressed. This "corrected" compression ratio is commonly called the "dynamic compression ratio".
So what isn't true? That crudely defines dynamic compression ratio. The dynamic compression ratio is also a numerical comparison (as ratios are) of the volumes of a cylinder, but with the larger volume redefined as having the cylinder height starting at the point of the intake valve closing, rather than at BCD. Whether or not, "some of the intake charge to be compressed" is forced "backwards out of the cylinder by the rising piston at very low speeds" is a fluid dynamic discussion and has no effect on either type of "compression ratio".
True enough.
Old Jan 21, 2007 | 09:37 PM
  #44
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The compression ratios are a numerical comparison of volumes. ...It is (as a ratio is by definition) simply a numerical comparison of the cylinder volumes with the piston in each of two different positions.
Which is why it's called "Static" compression. It doesn't change (it's not dynamic) because it IS a calulation based on fixed factors.
True enough.
It does have an effect. That is the very basis for the difference between static compression ratio and dynamic compression ratio. The fact that air leaks out at some RPM and air is "packed in" at other RPM (on a well matched combo), is why there IS a term, "dynamic compression". To explain why the actual cylinder pressure is not the same as calculated based on BTC cylinder volume, and TDC cylinder volume -or the same throughout the RPM range. Which you acknowledged in your last sentence.
What is you point besides arguing about the existance of a term that does exist which explains a condition that does exist?
Old Jan 23, 2007 | 07:37 PM
  #45
C4Techie's Avatar
C4Techie
The point IS, that you are clouding the issue with irrelevant (even though correct) information. The question was:
Will changing from a 2 barrel carb. to a 4 barrel carb have any effect on the dynamic compression [ratio] of an engine?
[inserted by me for clarity]
Fact: A compression ratio (static or dynamic) is a comparison of volumes.
Fact: Changing the carburetor doesn't affect the dimensions (volume) of the insides of the engine.
That's the point. That's all.
Old Jan 24, 2007 | 12:45 PM
  #46
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Static is. Dynamic isn't. I think from reading your postings that your perception is that "dynamic compression" is a comparison of volumes; the two volumes being the volume of the cylinder when the intake valve closes vs when the piston is at TDC. If that's what you're thinking then I don't agree. To me, the term dynamic compression is referring to the cylinder pressure that is a RESULT of cam timing, volumes and RPM. So to me, the term "dynamic compression" is a term that explains the factors that lead to actual cylinder pressure. If I am wrong about this, and "dynamic compression" truely is a term that describes nothing more that the delta in volumes between intake valve closure and TDC, then you're right. In that case clearly a carb swap isn't going to change engine internal dimensions.
No kidding. But it does affect cylinder pressure, unless it's so large that it's not a limiting factor.
Old Jan 24, 2007 | 01:27 PM
  #47
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I stand corrected:
Dynamic compression IS indeed a calculation that uses only two factors: volume of cylinder when intake valve closes, and volume at TDC. Obiviously those factors do not change with a carb swap (though cylinder pressure could), so changing a carb doesn't change DCR.
My bad.
-Tom
Old Jan 24, 2007 | 07:02 PM
  #48
C4Techie's Avatar
C4Techie
Thank you.
Back in post #41 I asked what VetNutJim meant by the term "dynamic compression", and I continued on after explaining that I was talking about the "dynamic compression ratio". In my last post, I even high lighted, in blue, where I had amended the question to read as I thought it was intended to read. Your statements were (are) correct as to some of the effects that can occur due to changes in DCR. After your second to last post, I was about to point out that it seemed as though you were confusing the terms compression "pressure" and compression "ratio". Then I read that you "got it". Great!
Old Jan 24, 2007 | 07:19 PM
  #49
Dominic Sorresso's Avatar
Dominic Sorresso
Anybody have anything else to add regarding 84 TBI?
Old Jan 25, 2007 | 12:25 PM
  #50
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yep, Dom, this thread is way off topic now, BUT I did get something sorted out for myself, and I'm happy for that.
Thansk for calling me out, C4Techie!
Old Jan 25, 2007 | 01:18 PM
  #51
Dominic Sorresso
Tom,
The discussion was interesting to me and I did think that the issue was a confusion regarding compression(lbs/sq.in.) v ratio. One of the reasons I swapped cams was to lower the compression in my cylinders because it was at the level where I felt I could use more overlap. With over 200lbs. in all cylinders, I felt the intake valve was closing too soon and I was losing power due to pumping losses. Now I fully expect that my hypothesis could be inaccurate. But the cam swap has proven to add more power and extend the rpm band 5-600rpms.
