optispark and timing
Old Jan 15, 2007 | 03:06 PM
corvette1989bham's Avatar
corvette1989bham
Default optispark and timing
replaced a bad opti on a 93 . it wouldnt run before . . . now cranks and runs . Timing seems way off like spark plug wires are crossed . . . triple checked they are not. Hard start and miss . I know the opti drive gear is slotted as well as the gear inside the timing cover. Both aligned fine. I cant imagine getting it 180 out , and if by some magical coincidence I did, it wouldnt run at all .. . . right? Any thoughts?
Old Jan 15, 2007 | 03:56 PM
VenkmanP's Avatar
VenkmanP
The symptoms of misaligned opti range from "no start" to "starts but runs rough, like wires are crossed."
Old Jan 15, 2007 | 06:21 PM
corvette1989bham
thx....opti and gear are slotted.....double checked fit before re assembly.....how can it be mis-aligned?
Old Jan 15, 2007 | 07:46 PM
corvette1989bham
bump
Old Jan 15, 2007 | 08:26 PM
MikeC4's Avatar
MikeC4
I've gotta ask, did you replace with a new Opti or remanufactured unit?
Old Jan 15, 2007 | 09:08 PM
corvette1989bham
I did replace with new gm . I just pulled the water pump again and re checked new gm wires ...they were correct. Now I sometimes do and do not get a code 41 . I have done the service manual diagnostic tree.
car runs ok then sputters ping and shuts off. I have replaced coil and module.
I doubt the optispark is on wrong because it runs fine for a little bit then acts up.
Old Jan 15, 2007 | 09:41 PM
STL94LT1's Avatar
STL94LT1
It would be really hard to get an early opti misaligned. If so, you would have to force the opti on. But, it sounds like either crossed plug wires or a misaligned opti.
Did you check to make sure all sensors were plugged back in after the install?
Old Jan 15, 2007 | 10:11 PM
pcolt94's Avatar
pcolt94
I would do a fuel pressure check just to make sure the pressure is OK. Low pressure would cause all kinds of running problems. Take a break from the ignition stuff and do a pressure check and cover another base.
Others have aligned the opti wrong and said it couldn’t be done. But from what I remember, it usually does not start. The opti should go on real easy and hit the cover with a tink. The bolts don’t pull it in, just hold it in place. But I think you know that.
Old Jan 15, 2007 | 10:18 PM
corvette1989bham
sensors and opti are ok . . . tracing code 41.
Fuel pressure good . 40lbs +
Old Jan 15, 2007 | 10:41 PM
pcolt94's Avatar
pcolt94
From what module is the code 41. ECM would be module 4 and CCM is module 1. I guess you would not know if there was a code before opti replacement.
Old Jan 15, 2007 | 11:10 PM
corvette1989bham
plenty of codes before opti - now getting ecm41. Looks like the ecm is bad.
Here is what I did....................
pulled plug on coil driver. Tested voltage with ign on .... .053
removed connector "a" from ecm ...voltage went to 10.xxx
Looks like ecm time.
Old Jan 16, 2007 | 05:01 AM
VenkmanP's Avatar
VenkmanP
I myself can't imagine how one can install it wrong, but so many people have managed to do it that I just have to accept it.
Do a search on camaroz28.com you will find lots of examples.
Old Mar 1, 2007 | 02:12 PM
Kryptonite's Avatar
Kryptonite
Default Master Mechanic
Guys I might be boasting a little here but my C4 had been down since October 05 and had been seen by many mechanics in the Atlanta area.
Bill Heard CHEVROLET HAD MY CAR FOR 9-WEEKS called me and said come get it we cant fix it. I finally got in touch with Chris a member of this forum corvette1989bham. I shipped the car to him just outside birminham and he fixed my car within a couple weeks. The dealership had messed up the wiring harness on the car so some pretty extensive investigation and troubleshooting had to be done to fix it. I just want to say if you have something you or noone has been able to handle SEND IT TO CHRIS he was very reasonable and had the means and the place to work on these cars. Thanks again Chris for ending my nightmare.
Old Mar 5, 2007 | 02:31 PM
Jerry9202's Avatar
Jerry9202
Default Fixed
What ended up being the problem? Do you know what he did to find it. I am struggling with my '92 (runs rough) and there is no one nearby that I trust--so I am trying DIY.
Old Mar 5, 2007 | 03:37 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
You CAN install an opti the wrong way. I've done it
Also check the leads going into the opti. Sometimes the computer hookup corodes.
Next up is the ignition coil and module.
Make sure the wires aren't crossed either.
Old Mar 5, 2007 | 05:15 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I agree you can install an old style the wrong way. the "key' on the ditrubutor is just some solder between two teeth. I almost installed my new one wrong last weekend. Finally got the keyway and key to line up and it "popped" on seating perfectly without having to push hard at all.
I found that even pushing it with my hand almost got it on in the wrong position!
Old Mar 5, 2007 | 07:13 PM
cerino2000's Avatar
cerino2000
so what was the outcome on this thread corvette1989bham?
Old Mar 5, 2007 | 09:59 PM
corvette1989bham
There were many problems, most of them from the technicians not knowing the proper way to test the different components and hacking up thw wiring harness to test circuits. The main problem was the opti and coil bad, next the serial data circuit was hacked up throwing all kinds of false codes. I completely cut out the serial data circuit and rebuilt my own. Wiring connectors for ignition module, and idle air control motor ruined from backprobing...replace all connectors. Replaced ECM due to jumper wire being installed backwards. In all, it took about 40 plus labor hours to fix a 7 labor hour job had it been diagnosed correctly the first time. Also, re-installed the original CCM to replace the used ccm that was installed by dealer when they thought it was bad too (it wasnt)
To optispark and timing
