C5 Brakes Winter Project1
Old Jan 21, 2007 | 02:46 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default C5 Brakes Winter Project1
Well, starting the 1st winter project - C5 brakes/Rotors for the 87. Setup was thru Chris @ Superior...
Here's the parts for the L side:
PowerCoated the bracket with my home system, call BlackChrome:
Did a test fit with adapter from "redrose/Andy":
I'll keep this updated as the install proceeds...
vinnie
Old Jan 21, 2007 | 08:59 AM
sonomacrew01's Avatar
sonomacrew01
I would suggest buying copper crush washers for the brake lines as opposed to the washers in the picture.
scratch that, I see copper washers in the first picture.. Good Luck!
Old Jan 21, 2007 | 01:40 PM
vinnies87's Avatar
vinnies87
Not a problem.
Old Jan 21, 2007 | 07:37 PM
gator79's Avatar
gator79
same setup I went with except I got the adapters from jeffvette. they look and perform well.
Old Jan 21, 2007 | 08:22 PM
vinnies87's Avatar
vinnies87
Yea, can't wait.... the kit has been setting for 3 mos now, so figured it was time, can't do much in the PNW now, raining all the time, so perfect for projects, along with headers and the HSR waiting for install, going to be a wonderful winter... She go in for painting in march, so trying to get all the projects completed before then...
Old Jan 22, 2007 | 09:18 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
NICE !!
As per usuall, you have a lot of cool winter projects. Will they ever end.
Old Jan 22, 2007 | 08:06 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
This job is one my wish list, but first I'll need new wheels, C5 brakes won't fit with sawblades.
"Setup was thru Chris @ Superior..."
Just curious, what was the total cost?
Old Jan 22, 2007 | 10:49 PM
patsfan's Avatar
patsfan
From: Swanton VT 2000 Navy Blue Mettalic M6 / 1991 Auto - Steel Blue 68,500 R.I.P
Old Jan 24, 2007 | 12:21 AM
vinnies87's Avatar
vinnies87
Total cost thru chris was $531.00 shipped
cost for c4-c5 adapter thru redrose $75.00
SS brake lines VBP $79.00
Assorted bolts - granger grade 10 - $14.00
To C5 Brakes Winter Project1
