Coolant Sensor wire
Old Jan 21, 2007 | 03:41 AM
rythmfly's Avatar
rythmfly
Default Coolant Sensor wire
Hello everybody, I have 1988 L98 that has a broken green wire coming from the coolant temperature sensor that goes to the digital display not the one for the ECM. I can see the end of the wire coming out of the sensor connector but I can't find were the other end of the wire is. Which side of the engine did the wire go to so that the signal gets to the display. Has anyone had to repair this wire before? Thanks for any help you can send my way...
Old Jan 21, 2007 | 04:36 AM
RRT vette's Avatar
RRT vette
Is the wire connected to the coolant guage sender? Are you wanting to know where the wire goes from there?
Old Jan 21, 2007 | 05:16 AM
rodj's Avatar
rodj
"I can't find were the other end of the wire is."
Differences over the years.
On my '87 comes out of wiring loom by Alt wiring
Old Jan 21, 2007 | 05:32 AM
RRT vette's Avatar
RRT vette
Hmmm, that sounds like the green wire that goes to the low coolant sensor in the radiator. On my 86 that wire comes out of the wire loom that goes to the main fan. Runs right by/under the alternator.
On my 86E, the coolant temp sender in the right cylinder head between #6 and #8 spark plugs...that green wire goes down and behind the engine into the firewall to the dash cluster. Not sure if it's the harness behind the distrubitor or the one by the battery. I think battery side. To tight to get a pic there.
There is also another green wire that goes to the EGR temp sensor that's in the cross pipe between the intake manifold and exhaust manifold. That green wire goes into the wire harness behind the distubitor.
Those are not the only green wires. Lots of green wires.
Oh, and there are differences in the wiring over the years. So rodj, you could be correct, but not sure why that wire would be at the front of the engine also.
Old Jan 21, 2007 | 06:05 AM
rodj's Avatar
rodj
Apologies , getting late here
Wire I quoted is 2nd fan switch.
Temp gauge wiring comes from loom to starter by knock sensor wire.
Same on spare '89 loom I have .
Old Jan 21, 2007 | 01:36 PM
rythmfly's Avatar
rythmfly
Yes! your picture is exactly the sensor I am talking about and I could see where the wire goes down under the engine about six inches and that is where it is broken. So from that point where did the wire continue to. Thanks for you picture...
Old Jan 21, 2007 | 07:27 PM
RRT vette's Avatar
RRT vette
To tell you the truth, I would have to get under the car to look for myself. As, stated the wire runs to one of the firewall main harnesses.
Old Jan 21, 2007 | 07:29 PM
RRT vette's Avatar
RRT vette
Yes, that is another green wire. From the temp switch between #1 and #3 plugs to the (optional) aux fan.
Old Jan 21, 2007 | 09:32 PM
Raidmagic's Avatar
Raidmagic
That wire should be in the harness by your alt. It runs the aux. fan though not the temp on the dash.
Old Jan 21, 2007 | 10:02 PM
_twisted_'s Avatar
_twisted_
that wire should run to the aux fan relay
Old Jan 21, 2007 | 11:45 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default green wire
Clarification:
the green wire at the left front of the engine runs the aux fan.
the green wire at the right rear of the engine is for the gauge.
The green wire at the front of the intake goes to the computer.
The green wire at the right front of the engine coming out of the harness on the frame by the back r/h of the radiator goes to the low coolant sensor.
the green wire for the gauge goes to the engine harness and meets with the wires in the plastic convoluted tubing coming from the left side of the car, and goes through the firewall connector that has the heat sensitive goo that is the firewall seal. It's where the plastic vacuum tubing goes through the firewall.
Old Jan 22, 2007 | 09:09 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Jan 22, 2007 | 03:20 PM
rythmfly's Avatar
rythmfly
You are right! I was able to find the wire comng from the loom with wiring going to the starter also. I had to peal away some of the loom to see where the other broken end of the wire was. Thanks to everyone for all their input on this one.
To Coolant Sensor wire
