questions about an engine build...
Old Jan 23, 2007 | 09:17 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Default questions about an engine build...
where do i start?
i want to improve the rockers, cam, lifters, valves... etc.
where do i start?
Old Jan 23, 2007 | 10:31 PM
Grease Monkey
anyone? can i pick the valve springs and rockers now then just change the pushrod length if i get a different cam?
also should i get the heads milled to raise compression or sould i get new heads?
Old Jan 23, 2007 | 10:48 PM
clf93lt1's Avatar
clf93lt1
all depends on how much money you want to spend.
Old Jan 23, 2007 | 10:56 PM
Grease Monkey
under a grand if possible...
Old Jan 23, 2007 | 11:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
Not to be a d!ck, but you got 6 other threads going on this
Upgrade your exhaust, port the intake-1.6 rockers and springs will all help
clf93lt1's Avatar
clf93lt1
i dont know much about crossfire motors, if you can do the work your self a gran should do alot.
Old Jan 24, 2007 | 02:57 PM
Deakins's Avatar
Deakins
If you do the work yourself you may be able to pull off a small solid roller cam/lifters job along with a valve job with spring set up. With the induction that sits on top of the engine you will not get the results that you would with a carburetor or modified TPI set up, but you will be starting to get things moving in the right direction so that when money permits you can put a good top end on the engine and make some good power. One piece of advice from a guy that runs a solid roller on the street(a very large one at that!) is save some cash and buy the endureX comp cams lifters. Without forced oiling the bearings will fail in a street engine that idles a lot around town(been there, done that!). PM me if you have any direct questions. Hope this helps!
Old Jan 24, 2007 | 11:12 PM
Grease Monkey
i know, but i can never get the answers i need... everyone just tells me to do it to another engine.
thanks
To questions about an engine build...
