Help! Will not crank! '92
the last time i tryed to start it it would not engage the starter but everthing else powered up. I am working on it now and its the same way, car is a 6 speed. There is no fire on the fuel pump fuse , R INS fuse, HDT MIR fuse, or the EMC fuse, also the fuse block under the pass side dash had 2 blown fuses. The fuses under the dash that did not have fire where the AB CRANK , the FP2, and the one marked
3. I noticed that somewher along the line the egnition cylinder lead for the coded key had ben unpluged , thougt the VATS might be set off
could some one tell me where it is located and how to bypass it.
Any other sugestions would be greatly apreceated! I have rplaced the key, egnition swith and the ECM . no change? I used the cool trick i found on this site and the guru site, the EMC just read ERR
and the CCM read code 41 loss of comunications, I assume its because the fuse for the EMC is not receiving juice. When the car first went down i could pushstart the car but it ran rough. I have replaced a few relays but the mauales dont even tell wher or what relays are for what!
Ther a lot mor i could say but il leave that for latter .Thanks.
Kossie
Learn to type too!
