Air Pump Eliminator Kit......
Old Oct 4, 2001 | 03:13 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Air Pump Eliminator Kit......
I was looking at the Eliminator kit and see that it is very simple design. I would imagine that someone has measurements off one of these. If that is the case could someone email or post the design so I can have one made. I work with a guy that has a machine shop and he said he would wip one out for me. Thanks.
Old Oct 14, 2001 | 07:32 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Air Pump Eliminator Kit...... (ski_dwn_it)
Anyone please :p:
Old Oct 16, 2001 | 12:02 AM
jcazin's Avatar
jcazin
no problem- just pay me 1/2 what I spent, and I'll send you everything you need.
Old Oct 16, 2001 | 04:29 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Air Pump Eliminator Kit...... (jcazin)
The point is to save everyone money, and to help everyone else out. I would be more than willing to help you out when I can. If I can save you 200 bucks on something I can figure out a way around, that's 200 you can spend elsewhere. In the end we all win. That's what this is all about. Helping others that may not have 200 bucks but would like to make mods. Don't get me wrong I do have 200 bucks, but don't want to spend it one something that is only worth 25. That's why I have money. Just my .02.
Old Oct 16, 2001 | 05:07 PM
GlockLT4's Avatar
GlockLT4
:confused: :confused: Post your design so we can all see... it's not like you've got a patent on it or somethin...
Old Oct 16, 2001 | 09:28 PM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Air Pump Eliminator Kit...... (Glock'94)
Careful guys, I think the manufacturer does...
Old Oct 16, 2001 | 09:30 PM
scorp508's Avatar
scorp508
Default Re: Air Pump Eliminator Kit...... (Red 90 L98 Coupe)
If they don't sell it for a profit though, I don't think it would violate anything.
Old Oct 16, 2001 | 10:09 PM
GlockLT4's Avatar
GlockLT4
Default Re: Air Pump Eliminator Kit...... (scorp508)
We might still have to have permission though...
Old Oct 16, 2001 | 10:29 PM
88L98's Avatar
88L98
Cruise-In II Veteran
nope. no one can stop you from making anything. besides, all you need to do is remove the pump with all its crap, and get a shorter belt
Old Oct 16, 2001 | 10:38 PM
88L98's Avatar
88L98
sorry but you cant "own" a metal bar and a pulley and say that no one else can make it. thats why there are varieties in exaust, intake, etc. dynomax are the same thing as borlas just cheaper. flo-pro's are the same thing as flowmaster, just cheaper. several companies make a version of the BPP vortex intake.
Old Oct 16, 2001 | 10:45 PM
GlockLT4's Avatar
GlockLT4
Default Re: Air Pump Eliminator Kit...... (88L98)
Well, I meant if you were to start selling it or something...
Old Oct 16, 2001 | 11:58 PM
h rocks's Avatar
h rocks
88L98, I think you have posted this "solution" of using a shorter belt before. I have a '90, and for the life of me I cannot see how to make that work. If you can post the routing diagram or picture, it would be *greatly appreciated* by MANY CF members. :cheers:
Old Oct 17, 2001 | 12:43 AM
TJR's Avatar
TJR
Default Re: Air Pump Eliminator Kit...... (h rocks)
I've looked at mine before, but I just went outside and looked again to be sure. The belt absolutely will not clear the power steering pump when routed straight from the alternator to the water pump. I even ran a piece of string across the pulleys to verify that it wasn't an illusion. Compounding this is the fact that the air pump is an integral part of the alternator mount. Without it, the top of the alternator has nothing to bolt to. The only way it might work is if you could move the alternator up where the air pump was, but that would also require a fab'd bracket and there may not be enough belt contact with the power steering pump pulley.
You could leave your air pump on if looks are not an issue. If you've removed the plumbing, there isn't much resistance in the pump itself.
[Modified by TJR, 11:51 PM 10/16/2001]
Old Oct 17, 2001 | 01:41 AM
88WHITE VETTE's Avatar
88WHITE VETTE
On the 88 ~90 you can't get away with this, if you want to eliminate the air pump you must put something in it's place. What I did, is eliminated many things like A/C, air pump and just tonight I eliminated the belt tensioner. I made my own eliminator bracket at work with couple pieces of aluminum and pulley that I got from local auto store. I would be happy to share this with you guys, but I don't have way to post pictures. If there's anyone in the Chicago area with digital camera and would willing to take and post those pictures, I would be more than willing to share my idea with you.
I eliminated the belt tensioner by making adjustable bracket from my eliminator bracket to the distributor. Distributor is the one that's adjustable/moving.
Let me know!
Ziggy
Old Oct 17, 2001 | 02:24 AM
88L98's Avatar
88L98
oh ok, sorry i misunderstood you. :cheers:
i just went out and looked at it, it seems i was wrong. i knew you could do it on a tpi f-body by rerouting the belt with a shorter one because ive done it, but the belt comming of the altenator to the water pump with no air pump would rub the power steering pulley on the vette. i still have my air pump, and it was kinda dim where i was looking. ill have a few hours before i have to go out of town 2morrow, ill take a look at it and see if i can figure anything else out.
[Modified by 88L98, 12:25 AM 10/17/2001]
Old Oct 17, 2001 | 05:39 AM
Aggravated4life's Avatar
Aggravated4life
You dont need measurements from any aftermarket kits...just take them from your car now.
Measure the length of the Smog pump brackets, height of the pulley and locations of the bolt holes into the cylinder head and you can make your own.
You can even remove the smog pump and brackets and set it on a work bench and custom or design a new bracket(s) to your style.That includes the top piece that holds the alternator in place.
Take it off, set it down and measure and design away.
Where did you think they got the aftermarket design in the first place?
The answer is what you have now so you can retain the same belt and etc.
[Modified by Bill's86Coupe, 3:42 AM 10/17/2001]
Old Oct 17, 2001 | 06:57 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Well I removed the guts (fins) from the air pump and capped the hole in the mean time. I also removed all the hoses, ect from the engine compartment. As soon as I get a chance to go to the dealership I will remove the metal hoses that go to underside of the car. I notices that the one area were all the hoses converge had some wires hooked to it. I'm sure it is some sort of vlave that directs the air....What should I do with the wires? No codes were sent with them disconnected. :confused: Perhaps I should just leave them alone. Any input? I did have one reply and the guy said he would give me the measurements. I will ask him if it is alright to post them here, if he says it is alright I will. Glad to see someone was willing to help out. See you all later.
To Air Pump Eliminator Kit......
Old Oct 17, 2001 | 08:08 PM
KYVette90's Avatar
KYVette90
I just bundled up my wires and hid them under the ac bracket.
Old Oct 17, 2001 | 08:56 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Air Pump Eliminator Kit...... (KYVette90)
that must be the hiding spot for the wires. Put mine in the same spot. Great minds must think alike! :D Thanks KYVette90.
Old Oct 18, 2001 | 07:39 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
I think the kit BPP makes is great. If no one supports those that have taken the time to produce things for us, then no wonder nothing else will come out for the C4 except home grown. Considering how much some stupid OEM stuff costs, I didn't think the price was that bad?
