Ltpws $#&*#@!!!
Old Feb 6, 2007 | 08:33 AM
jcs44's Avatar
jcs44
Default Ltpws $#&*#@!!!
I just put new tires on my 96 LT4. This car had run flats on it originally and came with the LTPWS which worked fine. I did not care for the run flats, so I put on normal tires (BFG KDW) which I like a lot better. But now my "Service LTPWS" light is on which probably means that the tire guys messed up a sensor.
Two questions: Does anyone know how to turn off that warning light without messing up anything else? Given that a wheels sensor is now bad, how do you figure out which one it is?
Thanks, JCS44
96 LT4 Vert, triple black
Old Feb 6, 2007 | 08:46 AM
94z07fx3's Avatar
94z07fx3
Just guessing here but I wonder if PCM4Less or some other outfit could program out the code for low pressure.
Did your car come with a jack, spare tire, and lug wrench?
Old Feb 6, 2007 | 10:39 AM
edcmat-l1's Avatar
edcmat-l1
The low tire pressure module is a stand alone module. It ties into the PCM, but just on the diag circuit. It sets the code and turns on the lite by itself, completely independent of the PCM. Take it to someone who has a tech2, so they can diag it. first tho, check the tire pressure, if one is low, pump it up and drive it to reset the system.
Old Feb 6, 2007 | 10:44 AM
90Z51's Avatar
90Z51
The FSM has a diagnosis to figure out which sensor is bad. If you just want to disable the light all you have to do is take the DIC apart and remove the bulb. That's what I did.
Old Feb 6, 2007 | 11:04 AM
jcs44's Avatar
jcs44
Thanks for the replies. I do have a jack, spare, etc. I'll check the pressure again, but I think its OK. The Chev dealer says it can be reset assuming the sensors are OK. We'll see.
Thanks, JCS44
Old Feb 6, 2007 | 11:01 PM
Dads90's Avatar
Dads90
My "service ltpws" comes on all the time. But its still operational. I have a slow leaker and it catches it every time. I would remove the DIC cover and just put electric tape over the cubical face the light is setting in. I got it on my "To Do List". Does the light need to be place to complete a circuit ? I thought so. Chime in if I'm wrong.
Old Feb 7, 2007 | 08:29 PM
SunCr's Avatar
SunCr
I'd take a look at how it works first - latest designs (at least everything I've seen from 2000 and up) have an ABS/Traction Control Interface. If that's true for the '96, I'd fix it, particularly if a tire jockey broke it.
To Ltpws $#&*#@!!!
