Rotor Prices ???
Old Feb 9, 2007 | 06:55 PM
9T3vert's Avatar
9T3vert
Default Rotor Prices ???
OK, I need some advice here.
Eckler's has replacement Rotors for $39.99. I checked AutoZone and they are at $66.99. What am I missing here?
Old Feb 9, 2007 | 10:27 PM
96GS#007's Avatar
96GS#007
First you have to make sure they're the same size...ie is AZ is quoting the 13" J55 front rotors and Ecklers is quoting the 12" standard rotors (thru '94)?
Next, where are they made? The cheaper ones tend to be foreign made and have fewer cooling vanes.
I use Raybestos rotors from RockAuto...~$45 each, stock OEM vane count, made in the US or Canada, and they're true (sometimes the cheap ones are warped right out of the box). I use these on road courses and go thru a set just about every other weekend during track season
Old Feb 9, 2007 | 10:50 PM
95BLKVette's Avatar
95BLKVette
I agree.
Otherwise you can check out the "Brute Force" rotors that are slotted and drilled...I have them on my C5 and they also make them for the C4....very reasonable from Rockauto....I get tons of parts from them....I think thre rotors are manufactured by Raybestos.
Good Luck
Old Feb 10, 2007 | 03:00 AM
montecarloz34's Avatar
montecarloz34
i got some from my monte from r1concepts.com all for for 175 and some grennstuff brake pads love umm look awsome and elminats some brake fade as well
Old Feb 10, 2007 | 11:10 AM
Aardwolf's Avatar
Aardwolf
I paid $35 at a local NAPA, no shipping charges.
Old Feb 10, 2007 | 02:35 PM
runner140*'s Avatar
runner140*
You usually get what you pay for. Good rotors cost $100.00 each.
Great ones cost more.
Old Feb 10, 2007 | 07:40 PM
96GS#007's Avatar
96GS#007
Old Feb 10, 2007 | 07:47 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
I got all 4 NOS for under $100, Corvette Central is where I got mine
Old Feb 10, 2007 | 08:17 PM
Bob CTS's Avatar
Bob CTS
I use Bendix and they where about $60 a piece, I like them.
Old Feb 10, 2007 | 08:31 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
A common problem with the cheap ones is "core shift".
This means the core mold that creates the gap between rotor sides and between vanes moves relative to the outer mold. So, you get a casting where the sides aren't the same thickness all the way around.
Then when it heats up, it expands unevenly (and dissipates heat unevenly), and the rotor will warp. It's a crap shoot on the cheap rotors. There is zero quality control.
Old Feb 11, 2007 | 01:23 PM
Gary04Z06's Avatar
Gary04Z06
Originally Posted by 96GS#007
I get mine from Rockauto also, been great for the track days.
To Rotor Prices ???
