valve springs
Old Feb 16, 2007 | 06:20 PM
rich653's Avatar
rich653
Default valve springs
putting a new set of valve springs on while I'm replacing valve seals on my 86, the ones I ordered are oem from gm, but they don't have that inner coil like the ones I'm replacing. does it make a difference ?
Old Feb 16, 2007 | 07:42 PM
RED86RAGTOP's Avatar
RED86RAGTOP
Rich, it doesn't matter as long as they are cheap! (inside joke)
Seriously though, did you get the LT4 springs that everyone seems to reccomend?
Dennis
Old Feb 17, 2007 | 07:47 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If they are the same spring, pull out the damper springs and put them into your new springs.
Old Feb 17, 2007 | 08:19 AM
rich653's Avatar
rich653
Thanks for that info agent 86 I was wondering if I should do that. Your always a big help.......
Old Feb 17, 2007 | 12:19 PM
RED86RAGTOP
Rich, you are using the 1.6 rockers right? Is there a coil bind issue using the stock springs with those? Just thought I would bring that up before you get too involved in the project.
Dennis
Old Feb 17, 2007 | 07:51 PM
rich653's Avatar
rich653
Dennis
not sure Dennis, any one else have any thoughts?
Old Feb 17, 2007 | 07:52 PM
rich653's Avatar
rich653
ttt
Old Feb 17, 2007 | 08:53 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Most recommend a stronger spring when going to 1.6 RR. On my stocker I'm going to use new LT4 springs. They are 101# as opposed to about 85# on the stock springs IIRC.
To valve springs
