Door Panel Removal
Old Feb 17, 2007 | 09:09 AM
93cruiser's Avatar
93cruiser
Default Door Panel Removal
Need help on romoving the RH door panel. I have romoved all of the screws including the one behind the door lamp. The panel is loose but something has it secured by the window switch. Can anyone offer some help and the proper sequence of component removal
Thanks for any help.
93cruiser
Old Feb 17, 2007 | 09:22 AM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
On my '84:
The ones in the carpet
The one on the side
One behind the door handle
Two in armrest area
Door lock switch needs poped off
Old Feb 17, 2007 | 09:49 AM
93cruiser's Avatar
93cruiser
I found a screw behind the window switch. All that seems to be holding it now is the door lock switch. I will try to remove it now.
Thanks Corvette for Life
Old Feb 17, 2007 | 10:15 AM
93cruiser's Avatar
93cruiser
Originally Posted by Corvette for life
On my '84:
The one on the side
Two in armrest area
Okay, now I am hung up on the door lock. This seems to be all thats left in order to remove the handle bezel and then remove the door panel. The fsm shows a screw underneath the door lock slide but I cannot access it. Any hints on this?
Old Feb 17, 2007 | 10:25 AM
Grease Monkey
The bezel, on my '84 at least, Is stuck to the panel, It doesnt have to come out of the panel to get it all out. Once the panel is loose you can reach back there and take the screw's out. I hope this helps.
Also on my '84 I dont have a screw there. But if your's is like mine then you can pry the door lock bar up and tuck it behind the plastic bezel... then you should be able to see if there is anything back there
Old Feb 17, 2007 | 11:28 AM
quickcat's Avatar
quickcat
With the door lock forward, pull it out until it comes off the steel rod underneath. You may have to reach in there with your finger to help it out. Now you can remove the plastic part of the door lock by pulling it forward and away from the steel rod. You will then see a screw behind the steel rod. You can nudge the steel rod out of the way with your screw driver to remove the screw.
If that is your last screw you can just pull out and up on the door panel and it should come right off.
Old Feb 17, 2007 | 11:30 AM
quickcat's Avatar
quickcat
Wait.....after getting that last screw you will have to wrangle the bezel around the door handle then the panel should come off.
It has been a couple of months since I have done it. You will get it.
Old Mar 4, 2007 | 02:13 PM
DWC4's Avatar
DWC4
Default C4 door panel removal and replace process
I need to do both of mine on my '92 and having done it years ago on my '85, I dread it more than root canal.
You think getting it apart is hard? Ha. Wait till you try to get that black sliding door lock plastic piece back onto that metal rod when you put it back together - I remember that giving me fits.
Anyone know of a well documented step by step of the removal and installation, with pics, like I've found here for headlight motor repair? That actually came from Corvette Fever I recall -
fyi that is http://www.corvettefever.com/howto/33098/index.html
they have this fine article with pics on door panel removal but this is for C3:
http://www.corvettefever.com/techart...w_adjustments/
Old Mar 4, 2007 | 02:21 PM
corvettedan22's Avatar
corvettedan22
[QUOTE=DWC4;1559223614]I need to do both of mine on my '92 and having done it years ago on my '85, I dread it more than root canal.
I dont know about that !
Old Mar 4, 2007 | 03:05 PM
jhammons01's Avatar
jhammons01
I just did this job. The Bezel comes off with the door.
The door lock slide linkage is what is hanging you up. The Bezel has a slot on the top that you won't be able to see until you get it off. The Plastic piece with the Orange/red tape has to be pulled toward you and worked and it will come off.
Then you'll be able to push the Rod up and out of the Bezel.
The door panel will now come off by lifting up off the top part where the window slot is.
Be careful the wires are all still hooked up. You'll need two hands for the next step. One to hold the panel while you un-hook the wires
To Door Panel Removal
