U Joints
Old Feb 18, 2007 | 08:33 PM
Black_Vette's Avatar
Black_Vette
Default U Joints
I am rebuilding my differential and would like to replace all the u joints on the half shafts and drive shaft while I have everything apart.
Iam wondering what u joints are good to use???
I would like to get something that will be stronger than the stock ones.
Old Feb 18, 2007 | 08:48 PM
sonomacrew01's Avatar
sonomacrew01
spicer
Old Feb 19, 2007 | 10:55 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Why? Are you breaking the stock units??
Larry
code5coupe
Old Feb 19, 2007 | 12:57 PM
MikeC4's Avatar
MikeC4
Originally Posted by sonomacrew01
spicer
solid, non-greaseable kind....
Old Feb 20, 2007 | 12:00 AM
Casethecorvetteman's Avatar
Casethecorvetteman
spicer
Exceptional choice
Larry
code5coupe
Why???? Cause the better they are the longer they will put up with abuse before they are out of spec or simply fail. Thats common sense really. So why not??
Old Feb 20, 2007 | 09:18 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I went to Lorco and bought solid U-joints. I don't remember the brand, but they were a well know manufacturer and were in stock and a whole lot cheaper than spicer.
Old Feb 20, 2007 | 09:28 AM
Casethecorvetteman
Brute Force?
Old Feb 20, 2007 | 01:21 PM
scorp508's Avatar
scorp508
Brute Force = Brute Cheapness, please don't use them. Get the spicer cold forged non-zerk units with the coating that is compatible with our aluminum halfshafts and driveshafts.
Old Feb 20, 2007 | 03:17 PM
ZBRA's Avatar
ZBRA
Are all 6 the same? Anyone got the part number(s)? Napa and O'Reliys both said they don't carry Spicer. Auto Zone and Advance both carry China-crap. Guess I'll have to find the Spicer joints on line, but that is near impossible without the part number.
Old Feb 20, 2007 | 04:21 PM
scorp508's Avatar
scorp508
Nah the driveshaft ones are a little smaller. I'm sure someone will pop in with the part #s, I'm at work right now.
Old Feb 20, 2007 | 04:29 PM
BillWelter's Avatar
BillWelter
Default U-Joints
Take the half-shafts and driveshaft to the Driveshaft place, they'll put Spicer joints with the right coating for aluminum shafts. Also, they'll use synthetic grease. Have them check balance on the driveshaft while you're at it. Mine was a bit off...
Old Feb 20, 2007 | 04:35 PM
KENS80V's Avatar
KENS80V
Here are the "Spicer" numbers for the coated type for use on the aluminum Corvette shafts. Driveshaft (1310 series)....SPL22-2X. Halfshafts (1350Series)....SPL30-2X. Here are the old numbers for the above U-joints, Driveshaft....5-786X. Halfshafts.....5-800X.
Best place/best price I ever got on these Spicer u-joints was from a "heavy truck" parts store. These are the best you can get, non greasable and well worth it.
Old Feb 20, 2007 | 04:42 PM
KENS80V's Avatar
KENS80V
Here are the Neapco "Brute Force" numbers, Driveshaft....1-0626BF. Halfshaft....2-0617BF. These are also the coated type for use on aluminum shafts. Please note that these U-joints are listed as greasable. I think the grease (zerk) fitting is in the end of the cap not the body of the joint.
The only other U-joint to consider are the Precision "Super Strength" brand but I don't see a listing for a coated cap type to be used with aluminum shafts. Here are the part numbers for the noncoated type, Driveshaft.... #280 (greasable/in cap zerk fitting). Halfshaft....#232 (greasable/in cap zerk fitting).... #231 (non greasable).
The main thing to keep in mind is the driveshaft uses a 1310 series size and the halfshafts use a 1350 series size. The caps on the u-joints should be coated to help prevent galvanic corrosion between the dissimilar materials.
Old Feb 20, 2007 | 04:52 PM
vader86's Avatar
vader86
Go to Tom's Differentials and order Spicer cold forged w/o zerks, that is the ONLY brand you ever need to put in.
Old Feb 20, 2007 | 05:56 PM
ZBRA's Avatar
ZBRA
Thank You!
I have all three shaft out right now since I'm installing a new engine, clutch, and replacing every bushing I can find. No better time to replace the u-joints.
Old Feb 20, 2007 | 06:11 PM
rocco16's Avatar
rocco16
He didn't say he wanted "better", he said he wanted "stronger".
U-joint can fail for reasons other than breakage. In fact, for every 1000 U-joints that fail, 9999 of them fail for reasons other than breakage. In those 9999 cases, a stronger U-joint will not last longer. That's why I asked if he's breaking them (or, just wearing them out?).
"Better" and "stronger" are not necessarily synonymous. You can have a U-joint with the highest tensile strength of all, but if the needles fracture, or dry/wear out from lack of lubrication, you're still gonna' have to replace it............
Maybe "stronger" and "better" are the same to you. If that's the case, then what I said above probably doesn't make much sense....and I apologize for taking up so much of your time.
Larry
code5coupe
Old Feb 20, 2007 | 11:47 PM
Casethecorvetteman
You knew exactly what i meant mate. Its common sense. Read the part where i say "out of spec" and have a think about what that means..... I never mensioned 1 single thing about breaking anything. Out of spec/simply failing and breaking are not necessarily synonymous.
Id heard exactly the same thing mate yeah
To U Joints
Old Feb 21, 2007 | 11:07 AM
rocco16's Avatar
rocco16
Don't confuse common sense with assumptions, Case.
When the PO said he's looking for something "stronger", you assumed he meant "that wouldn't wear out so fast"....and maybe he did, but that's not what he said. So I asked for clarification.
You might be a mind-reader, but I am not.
He said "stronger", this tells me he's experiencing problems with a weak part that is breaking.
If he'd said "longer lasting" or "more durable", then he might be talking about something else entirely.
Regardless, I think several people have pointed him towards the items he is searching for. So,
Larry
code5coupe
Old Feb 21, 2007 | 11:39 AM
Casethecorvetteman
I never made assumptions in this case chief, i never needed to. It was obvious what he wanted. He wanted a durable uni joint.
Old Feb 21, 2007 | 03:12 PM
rocco16's Avatar
rocco16
Case, Case, Case...you assumed he wanted a "durable" U-joint when what he said was...
As you said, "durable" and "stronger" are not synonymous.
Any time one hears "It's obvious.", you know it's really not.........
Give up, mate, you cannot win this one.... ...but thanks for playing!
Larry
code5coupe
