Rear End Differentials
Old Feb 24, 2007 | 10:37 AM
JIMVET's Avatar
JIMVET
Default Rear End Differentials
I have a 1990 L98 coupe with a Thermo Master Hypertech Chip and a 160 PowerStat, Cat Back Exhaust. I'm not happy with my 1/4 mi. et.
The rear-end is stock, what kind of rear-end would be good for track and street and what could I expect from it?
Jim
Old Feb 24, 2007 | 10:47 AM
AKS Racing's Avatar
AKS Racing
auto or std trans? If auto, I have found the 3.33D44 works well. If std, then you already have the 3.33D44 or the option 3.54D44, which are both good rear gears.
Aaron
Old Feb 24, 2007 | 12:05 PM
JIMVET's Avatar
JIMVET
Automatic Transmission
Old Feb 24, 2007 | 01:14 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Then if you have the standard A4 ratio, it's a 2.59:1. Even the optional 3.07:1 D36 diff will be a noticeable improvement from that. You'll need to check your option codes to see which one you currently have. A higher stall converter would be a real asset too.
To Rear End Differentials
