I've said it before, and I'll say it again, "if someone would come up with an Idler pulley pulley's system for the L-98, so that an Electric Water Pump could bolt up, They would make there million". I'm surprised Maziere hasn't come up with something. Hey they would sell more of there product... JMO
you have to come up with your own custom setup i have one on my car (85vet) (ralph) (skidwnit) and i am sure there are others out there also just to name a few
I just bolted mine right on
I cut the lower brace to the Idler pully that bolts to the lower portion of the water pump and spaced the upper part of the a/c pully.
I took it up to 7400 rpm's and is has held so far.Napa has a 77 5/8 belt that will fit.Make sure you rev it up before you take it out on the road,you need to make sure the belt doesn't walk back towards the engine and tear up the belt.Takes a while to get it right but it works for me
