No start, alarm problem? 84'
Old Mar 4, 2007 | 02:44 PM
OTRA84's Avatar
OTRA84
7th Gear
Default No start, alarm problem? 84'
Bringing my 84' 4+3 out of storage and having a no start problem I believe is related to the alarm system.
Symtoms...
1. no crank or click
2. Horn blows constant, not intermittent(I unpluged it for now)
What I have tried....
1. unpluged solenoid interrupt relay and jumpered
2. horn stops
3. cranks, no ignition
Where I'm headed....
1. Anti theft module
My questions...
1. Am I on the right track?
2. Does the module cut power to the ignition circuit? (sounds dangerous if it were to malfunction while driving)
3. Best way to remove bread loaf panel (any tricks?)
4. How to bypass module
Right now I'm not too concerned about having the alarm work, I need to get her running and smog checked soon.
BTW I'm new to the forum and have read a ton of good info but nothing like this problem.
Thanks in advance.
Old Mar 4, 2007 | 02:59 PM
Kale's Avatar
Kale
You might want to try the C4 tech forum.
You can plug a resistor inline with the anti-theft module, and defeat it. I did this with my 86.
symptoms of no start = soft click, but plenty of battery and gas to go around.
Old Mar 4, 2007 | 03:03 PM
OTRA84's Avatar
OTRA84
7th Gear
Sorry, thought i was in the c4 forum. How do I move this or do i just repost.
Dang newcomers!
To No start, alarm problem? 84'
