Rebuilt?
This car has 160k miles on it, and the only thing that shows wear are the seats. I put some Iggee's on and took care of that. i have replaced the brakes and now the ECT sensor which was making me crazy, but other than that this car acts like a good used car, but not like a 160k mile car. Runs really tight, shifts strong, doesn't smoke or leak a drop and everything works great. The drive train seems so good I am wondering if it has been rebuilt. Carfax doesn't tell me anything to that point.
I have been looking for signs and there are some bolts here and there that look like they may have been wrenched on, and I noticed some orange gasket sealer peeking out from the exhaust manifolds, and I can detect a blue head gasket peeking out as well. things are so clean, but not detailed that I wonder.
Other than those small details, what else can I look at to give me a sign of original or rebuilt?
the underside of the car has zero signs of any leaks or crud build up. A little dirty from the road, but no build up or oily grime.
the orange on the exhaust manifolds is a copper based sealant that rebuilders that I have known in my past have used with great success on exhaust manifolds, even with out gaskets.
I can see inside the valve covers from the oil cap and it looks spotless, and the rocker arms seems to have good travel while running, indicating a cam with good bumps and no flat lobes.
The wiring seems original, but there are some broken retainer clips that I had attributed to age, but maybe from an overhaul.
Thanks for the feedback.
The are the type that gets everything fixed, replaced, cleaned polished and generally spends a lot of time AND money on their Vettes.
If so, it will be just about good as new. Count yourself lucky if you got one of THOSE Vettes. They ARE out there.
The ones owned by the 'normal' people are out there also.
To those folks the Vette is JUST a car just like their Yugo or their VOlkswagen.
Their usually pretty easy to spot... nothing you see will look like anyone gave a chitt about the vehicle.
Worn out tires, brakes, upholstery. Bulbs out, dirty carpets, dirty engine, the usual things that tip you off about a used vehicle.
You can revive those Vettes, it's just a LOT of time and money.
Glad you got a good one.
