Sorry I dont have a digital camera right now,
but I do have a great description.
Next to spark plug on cylinder #8 just
to the right of the plug there is a sensor
on the head. It appears to be a screw in
type sensor with a plug in connection
and one red wire and one green wire
coming off of it. Any help is appreciated.
The service manual shows it to be a coolant senser but not what it controls. The knock sensors are in the coolant drains in the middle lower of both sides of the block.
Coolant temp sensor, Thanks.
Now I have to buy a new connector
since the red wire is broke right at
inlet. Gotta find where to splice
into the red wire, only see the
green wire going into a wire shield,
pulled back the shield and no red wire.
Knock sensors near the bottom of the block near the oil pan rail.
91 earlier blocks is a one wire temp sensor on the passenger cylinder head, between cylinders 6-8.
92 up blocks there is a two wire sensor connector for engine coolant temperature, between cylinders 6-8.
I had book 1, in the house, of a 93 manual and the wiring diagrams showed this.
I can go to the shop tomorrow and get the 92 books if necessary.
Help me to understand
My1992 LT1 / 6 speed has the sensor with only one "Bluish/green" wire at this location , I do not see any other red wire broken in the harness.
Everything works fine on my car , Wonder why you have two wires on your sensor?
