ZF6 fluid
Old Mar 11, 2007 | 08:39 PM
Camaro350z28's Avatar
Camaro350z28
Default ZF6 fluid
Looking to change the tranny fluid in my 94. I have read a couple places, there is a 10w30 from GM and a 10w-60 from BMW? what do you guys use and or suggest? is there more options?
Old Mar 11, 2007 | 09:24 PM
tjwong's Avatar
tjwong
Castrol BMW fluid.
Old Mar 11, 2007 | 09:28 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
This is one of the most debated subjects on the forum. Everyone will swear by what their using and say anything else is junk.
I would think either of those two fluids would be ok, since they are both recommended by the zfdoc.
That being said, I am using the Amzoil in mine. If shifts very smooth and I haven't had any problems at all.
Old Mar 12, 2007 | 01:56 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I use a quart of Canola oil, and one 12oz jar of Mayonnaise.
Old Mar 12, 2007 | 02:00 AM
bogus's Avatar
bogus
We are talking transmissions, not S&M.
DISCLAIMER: I don't know this first hand, it is simply Internet based rumour and innuendo. This means it must be true.
Old Mar 12, 2007 | 02:03 AM
CentralCoaster
What's S&M? Sweatpants and Meatballs?
Old Mar 12, 2007 | 02:06 AM
CentralCoaster
Changing ZF6 Fluid - C4 Guru
bogus's Avatar
bogus
You're even kinkier than the web implies.
Old Mar 12, 2007 | 02:51 AM
cv67's Avatar
cv67
St. Jude Donor '05
That sounds very well rehearsed.
LIES!!
Actually I spoke to a nameless ZF guru last year and he was experimenting with running corn oil in them. Okeeee....
Old Mar 12, 2007 | 02:55 AM
CentralCoaster
Just click the link, everything you need to know is there:
C4 Guru
Old Mar 12, 2007 | 03:54 AM
Zrxmax's Avatar
Zrxmax
I will bet everything slip and slides just fine at your house with those chicks helping you out !
Old Mar 12, 2007 | 07:56 AM
kennedys22's Avatar
kennedys22
I used the factory spec oil. Went to the Chevy dealer. Sorry but I don't have the part number. The factory oil is good. The BMW oil is recommended also. You should be able to get the BMW (Castrol oil) from a dealer also. I would definitely choose one of these choices as recommended by ZF. It is not standard 10X30.
Old Mar 12, 2007 | 10:40 AM
bogus's Avatar
bogus
C4 Guru
oooh... CC's favourite singer! Did you all know CC is the president of his Fan Club???
Old Mar 12, 2007 | 11:16 AM
ScaryFast's Avatar
ScaryFast
No, Spaniards and Mexicans. Apparently you're not Bi...
Lingual.
I use the BMW Castrol, it's convenient because it's the same stuff I have to put in my M3 - I have it lying around the garage. Works fine, many many track days and the transmission has not exploded.
Old Mar 12, 2007 | 11:46 AM
dizwiz24's Avatar
dizwiz24
DO NOT USE THE CASTROL fluid in your ZF6 transmission.
ZFDOC lives in Arizona which has Disney World type weather compared with where I live in ohio. The Castrol BMW crap fluid takes time to warm up and still may never work right. I realize he has devoted his life to the ZF6, but, as a ZF6 user, I do not agree with his recommendation.
ZFDOC also told me I needed either my clutch hydraulics replaced/bled properly (which I did) or my transmission synchros rebuilt (at a cost of thousands of dollars) when I described to him the symptoms I had (grinded shifts, missed shifts under WOT runs, etc.). In some cases the gear lever would not move into the next gear during WOT type runs.
When I switched back to the proper GM pn 5w-30 factory fill all these problems disappeared.
I was going to buy a new transmission.
So the choice is yours:
Option A: Run with what GM factory engineers recommend you run with and no-ones complained here about missed shifts, grinded gears, etc.
Option B: Try risky BMW Castrol 10W-60 where some claim its great and others claim it can ruin your car.
Id rather try 'tried and true' option A. But thats just me. You'll do whatever you want.
Old Mar 12, 2007 | 11:57 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Would that be Kraft Mayo, or the store brand?
(decisions, decisions...... )
Larry
code5coupe
Sidney004's Avatar
Sidney004
Factory GM fluid. I went thru the same options with mine. Replaced it with the factory fill and it works perfectly. If it ain't broke don't fix it!
To ZF6 fluid
Old Mar 12, 2007 | 12:13 PM
dizwiz24's Avatar
dizwiz24
Thank you. Right here is somebody else who agrees with me.
Im not just something raving fanatic.
Old Mar 12, 2007 | 12:14 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
I am running the Castrol BMW stuff and it is fine
It is the recommended substitute fill by ZF
You know what they say about opinions
Old Mar 12, 2007 | 12:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
I think the General had a good idea of whats going on.
