Uhm, why pay $1250 to have used heads reworked? Just what flow
values do LPE and TPiS quote for ported 113's, anyway. Not only the
peak values, the whole series across the board.
Has anyone looked at the Trick Flow 175's? Priced them? Considered
the bang/buck?
Anyone?
The most expensive pair of TFS 175's at Summit costs less than the
$1250 port job mentioned above. The basic ones are hundreds less.
What am I missing here? Time after time, people turn up their nose
at these things and I don't understand why.
I'll add that I've got nothing against the AFR 180 Eliminator's - aside
from the point that, out of the box, they are not a direct replacement
for the 113 because of the chamber size. I imagine AFR could change
this easily by offering a version with a smaller chamber.
THAT WAS MY POINT EARLY ON IN THE THREAD - I WOULDN'T DO IT
The price at the link for for bare heads with 64cc
or 72cc chambers. Add $318 for single and $370 for
double springs, price to mill them to 58cc is unknown.
No flow rates provided that I noticed.
Here's an Ebay link for the same heads with valves and springs for $990, but again no flow numbers. Does anyone have any experience with them?
Thanks for all the input guys. I did find a super chevy link with flow numbers for the Dart Pro One 180cc heads. They appear to flow pretty decent, but obviously I'd still have the 64cc chamber to deal with.
the bang/buck?
Anyone?
No snub from me buddy... Although I didn't buy those, I bought the hybrids, made by TFS, "Summit" 170's w/62cc chambers and used .015" compressed head gaskets with them to get comp. ratio where I wanted it. So far, and even with my new combo far from dialed in, I'm very happy with my $950 investment.
That's another way to achieve the goal, but I believe that quench
area suffers a bit when a thin gasket is used to compensate for
a larger than optimimal chamber
This is a good opportunity to point out that although I've been going on
about one particular line of heads, it isn't about the brand - it is about
suitability for the application.
The characteristics of these heads just seem to make them the optimal
performing, most closely suited direct OEM replacements for L98's with
D-113's that are currently known to me.
