Port heads or replace them
As of now the car is stock heads/cam, but shortly I'll be buying an LPE 219 cam from Vic'89. So in the not too distant future this cam will be going in the car and I'm figuring it will be a good time to do something with the heads as well. All other parts are going back on the car, meaning I'm keeping the LTR set-up. I could see possibly going to a SR down the road, but for now I'm thinking it will run fairly decent with the current intake, plus I'm curious about how quick the car will run while still retaining this set-up.
My goals are simply to get the car to run quicker in the 1/4 without a huge amount of money. I'd like to see the car running in the mid 12s consistently and low 12s in good weather (high 11s would be cool too
) I'm really not looking for anything wild, just a street car that holds its own at the track. Looking at my goals for the car and the set-up that will be in the car am I best off reworking my stock 113 heads (some porting, maybe larger valves) or going with some aftermarket heads. I really don't see any big plans for builds in the future so I don't want more head than I need. I know there's a vast amount of aftermarket heads out there, but I'm wondering if my current heads re-worked a bit would get me where I want to be.
Any opinions would be appreciated.
T.A.
AFRs would probably be at the top of my list if I go aftermarket, but I was hoping to be able to get away with a less expensive route.
They claim to have developed the CNC program for LPE. From the conversation it sounded like they could get around 270 cfm intake flow, at a cost of around $1000 or so, with the cost being somewhat dependent on the hardware and the extent of services, milling, cc'ing, etc.
I thought this sounded pretty reasonable, compared to the LPE and TPIS pricing.
For me its still a toss up over putting $1000 or more into my 113s or buying a set of trick flow 175s for around $1100.
I like the idea of having them done locally.
Here's a link to cfe
http://www.cferacing.com/products_gm.htm
On the financial side, if you can buy performance heads ready to install for $1,100 and sell your #113s for $400-$500 there no contest.
) I'm really not looking for anything wild, just a street car that holds its own at the track. T.A.
If you can dissasemble your motor then you can port your own heads. I have probably done 20 sets at this point and it has never failed to make an enormous difference in the motors output. For me porting a set of heads and a $200 local valve job is free horsepower and it is the way to go for what you have expressed that you want.
My last effort was my 94 LT1 automatic and it put down 326 RWHP with little more than a set of shortys, home ported heads, and a cam so mild most people would have told you not to bother putting it in.
Roy
I reworked my heads because I wanted the experience and like the satisfaction of doing things myself. It was time consuming but enjoyable and the end result did look impressive. I didn't go crazy making the ports larger, I concentrated on the pockets and chambers.The machine shop that did my new guides and valve job was impressed with my work, that made the job even more satisfying.
My consideration includes by the time it is said and done(porting, valves etc. etc. VS/aftermarket done) you're almost at the same investment, this would additionally allow for future changes (small stroker etc.)
