LT4 Engine New in Crate. ?? $ value
Old Mar 21, 2007 | 07:42 PM
63redcoupe's Avatar
63redcoupe
Default LT4 Engine New in Crate. ?? $ value
What do you guys think a brand new, still in the crate LT4 engine would be worth? I found a guy that has one that he bought from GM in 96. It's still in the original GM crate and has been in a climate controlled storage building ever since. It's complete with the flywheel, clutch, bellhousing, exhaust manifolds, Intake, injectors, etc. Basically a "bolt in and go engine". I asked how much he wanted and he replied, "Make me an offer that I can't refuse". I didn't have a clue so I said I would have to ask around. (I didn't want to make a fool out of myself by "lowballing" him.)
I'm thinking it would be cool to install it in my 86. Tell me what you guys think . Thanks.
Old Mar 21, 2007 | 08:26 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
There was a LT4 crate for sale on this forum i think for $5500.00. If you do a search in C4 parts you will find it.
There is one for sale on e-bay as well.
Old Mar 21, 2007 | 08:42 PM
Strick's Avatar
Strick
It would work better in my 92.
Old Mar 21, 2007 | 08:46 PM
k99ja04's Avatar
k99ja04
Probably not worth as much as this guy is hoping. LT4's are no longer the cool engine for streetrod projects... LSx's are in. But I would ballpark it $4000-5000 depending on accessories wiring, PCM, etc.
Old Mar 21, 2007 | 08:54 PM
cv67's Avatar
cv67
St. Jude Donor '05
Id start at half that and go up from there.
Old Mar 21, 2007 | 08:59 PM
mrc24x's Avatar
mrc24x
How does $3372 sound w/ warranty????
http://www.sdparts.com/catalog/crate...teEngines.aspx
or $3118 if they still have any...
http://www.gmpartsdirect.com/results.cfm
Old Mar 21, 2007 | 09:07 PM
aminnich's Avatar
aminnich
Think about. New, never run, and 11 years old? Just how well oiled, preserved is it internally? Seals, gaskets, even rings would worry me.
Offer about 1/2 what you think it is worth, or just walk away.
Old Mar 21, 2007 | 09:23 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
This is way more than a long block. $4000. You will probably still need harness and ECM etc. Not plug and play for sure.
Old Mar 21, 2007 | 09:36 PM
lt4obsesses's Avatar
lt4obsesses
In storage for 11 years? Never run? My first question would be, why? I'm sure it's possible but I would be a little skeptical. Plus, as was said before, many of the composite materials inside could be rotting. You may want to rebuild just because of that. I would start @ $1500 maybe, no more than $2500 because either way it will cost you some $$ to get it running. Sometimes no miles over 11 years is not a good thing.
Old Mar 21, 2007 | 11:15 PM
etteroc27's Avatar
etteroc27
Stored well it should be alright. The heads and intake are worth more than $1500. The cost to buy the parts would be way up there. It should be worth $4500 to $5500. I built a 383 stroker that got put in the back and covered up, and it did fine when I pulled it out and put it in a car seven years later. Pre-oil it before trying to start it and I would bet it would do fine.
Old Mar 22, 2007 | 11:04 AM
Akcelr8 N VA's Avatar
Akcelr8 N VA
I wouldn't worry too much about it being crated for 11 years. I purchased a GMGoodwrench LT4 long block in October from Pace Performance that was built and crated in 1997. It's now in my car and running fine (with the exception of high oil pressure due to a HV pump with high pressure spring, but that's another story!). By the way, I paid $3100 for the long block without flywheel.
Old Mar 22, 2007 | 11:10 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
LT4 heads (new) sell for ~$1500.00. GM LT4 intake, new, on Ebay goes for $700 to $950.00
I sold a LT4 intake on ebay last year with a starting price of $250.00 and it sold for $950.00!
Old Mar 22, 2007 | 11:25 AM
rickneworleansla's Avatar
rickneworleansla
Luckily the prices on those have been dropping since the release of the Edelbrock. I've seen some go for $550.
I think this engine would be best sold to someone who needs a replacement LT4 to keep it stock. You can purchase something freshly rebuilt for around $5k with more power. If it was me I would offer about $3500 and deal up from there.
Old Mar 22, 2007 | 11:30 AM
63redcoupe's Avatar
63redcoupe
Thanks for all your responses. Perhaps I should elaborate a little more about the engine. I'm not concerned in the least about it having been stored for so long. The owner is a retired GM employee who purchased it for a project and didn't use it. It, along with a brand new LT1, a brand new LT5 and several brand new big blocks have been stored in a heated and humidity controlled garage. The spark plugs have been removed, cylinders oiled and desiccant plugs installed in each cylinder. To say this guy is **** about his collection would be an understatement.
There is no wiring harness or ECM but I'm not concerned about that. Those are readily available. I know it won't be "plug and play" into my car but it's not like I have to re-invent the wheel to install it either.
I don't think he is looking to get rich from this and judging from the other "toys" I saw sitting around, he's doesn't need the money.
I think I know now from the responses what the low and the high range should be. I'll visit him again and see what I can work out.
Thanks.
Old Mar 22, 2007 | 11:43 AM
billybonesmusic's Avatar
billybonesmusic
cool, let us know how it works out!
(if and when you get it, we will be here to help you!)
To LT4 Engine New in Crate. ?? $ value
