Coilover front end spring rates?
Old Mar 26, 2007 | 12:40 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Any of you guys running progressive rate springs
They start off soft getting stiffer as the spring compresses.
We used to do that on a race car. It allowed for a smaller sway bar.
Old Mar 26, 2007 | 07:35 AM
LD85's Avatar
LD85
Originally Posted by red L98
if u drag race the car is not going to transfer very good with coilover in front unless ur making big power or have a low rate spring.
I "might" go to the strip once a year, but I could see loosening up the rear spring a little if necessary.
It is not a real concern for me but it is good to know.
Old Mar 28, 2007 | 03:23 PM
LD85's Avatar
LD85
I hate to ask this but I was in the process of ordering the Heim Links and I noticed that Exotic Muscle has Bilstean Coilovers.
Anyone use the Bilstein coilovers?
OK, I did some searching and it looks like the Exotic Muscle CO's are Bilstein non-adjustable shocks.
The good part is the front spring is 2.875 (7/8") diameter.
Edit #2
I ordered the Heim Links today from EM, they should be here mid next week withan insatll on on April 7th!
Old Mar 28, 2007 | 10:09 PM
klkordzi's Avatar
klkordzi
Check out this post by Mo_Bandy. If you price out the parts thru Jegs or Summitt the cost is very similar to Exotic's price and you get the adjustable shocks.
Old Mar 28, 2007 | 10:11 PM
klkordzi's Avatar
klkordzi
Sorry forgot the link
http://www.ndneyes.com/mo/coil.html
Old Mar 30, 2007 | 01:39 PM
LD85's Avatar
LD85
OK, I ordered the QA1 parts today based on Mo's web site. Ordered teh Heim links last Wednesday, so all parts will arrive by next Wednesday,,, install a week from
Looks like I'm going with 400# Front & 275# Rears.
Thanks to eveyone for the helpful input,,,,,,
Overall the experience of forum members that actually run CO's has grown since 2003 when I last considered this. So I feel much more comfortable going this route.
Old Mar 30, 2007 | 08:48 PM
A95Y's Avatar
A95Y
I posted a similar question in the road race forum you may want to peruse.
http://forums.corvetteforum.com/show....php?t=1592108
Old Mar 30, 2007 | 09:10 PM
LD85's Avatar
LD85
Cool, great info!
so on the rear, you only moved the shock hole, and you used the original bolt mount holes?
Old Mar 30, 2007 | 09:17 PM
A95Y's Avatar
A95Y
Originally Posted by LD85
Cool, great info!
Yessir
Old Mar 31, 2007 | 10:16 PM
A95Y's Avatar
A95Y
Default red L98
How low rate of spring do you suspect? I go to the dragstrip frequently.
Old Apr 2, 2007 | 08:55 PM
LD85's Avatar
LD85
Mr. Summit dropped these off today!
Old Apr 4, 2007 | 01:33 AM
Mo_Bandy's Avatar
Mo_Bandy
Have fun
MO
Old Apr 4, 2007 | 01:58 AM
  #33
Mo_Bandy's Avatar
Mo_Bandy
Cheetah,
Thank you for the kind words, if you have any questions please feel free to email me or PM me i'll be happy to help you out...
MO
Old Apr 9, 2007 | 11:24 AM
  #34
briannutter's Avatar
briannutter
I'm running a 450lb spring in mine and it feels pretty soft. I guess I was expecting it to be a bit stiffer than my o.e. '94 fe-1, but it doesn't "feel" like it. Maybe because it's more compliant by design. I'm pretty certain I'm going to go to at least 600 for hpde usage.
Old Apr 9, 2007 | 04:56 PM
  #35
LD85's Avatar
LD85
I wont know how the 400's feel for another couple of weeks.
Maybe you just got used to them,,, did you attempt to adjust them?
Old Apr 9, 2007 | 11:31 PM
  #36
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Hey Buddy,
Hope all is well!
I came across this topic...I wanted to ask,do you need to reinforce the front shock supports? I heard the 84-87 frame-shock areas were thinner then the 88 and up cars,and cracks in the metal can happen,or along the welds?
May just be a urban legend for C4s but just wanted to say check that info out.MAybe someone reading will know.
TAlk more soon!
Old Apr 10, 2007 | 06:55 AM
  #37
LD85's Avatar
LD85
Originally Posted by Bill's86Coupe
Hey Buddy,
Hope all is well!
TAlk more soon!
Hey Bill, I hope you are doing well, drop me an emial when you can.
I will check on the shock towers this weekend. If necessary, I can weld supports onto the sides of the towers if necessary.
I have not heard from many people that have them on 84-87's.
To Coilover front end spring rates?
Old Apr 11, 2007 | 01:15 AM
  #38
Mo_Bandy's Avatar
Mo_Bandy
Ld85,
sorry I can't help you on this question, like poseted above i heard they were weaker but I tend to agree it could be "flklore"...
Regards,
Mo
Old Apr 11, 2007 | 07:06 AM
  #39
LD85's Avatar
LD85
Thanks MO, I looked them over and I will add some weld to the side of the shock towers and if neccesary, I will add some 1/8 or 3/16 stainless tell to the outer profile of the tower too.
Adding weld is the easy part!
Old Apr 29, 2007 | 03:01 PM
  #40
A95Y's Avatar
A95Y
Don't weld before you bend the towers out. The springs hit the sides. I used a giant crescent wrench. As far as the weight transfer for drag racing, I was at the track last week and one of my buddies said my car took off like a missile. It didn't lift and didn't squat, just went. I busted the spider gears in my Dana 36 with cheater slicks, still managed a 12.77 with a 1.7 60 ft.
