Coilover front end spring rates?
Old Apr 29, 2007 | 05:20 PM
  #41
LD85's Avatar
LD85
Originally Posted by cheetah
Don't weld before you bend the towers out. The springs hit the sides. I used a giant crescent wrench. As far as the weight transfer for drag racing, I was at the track last week and one of my buddies said my car took off like a missile. It didn't lift and didn't squat, just went. I busted the spider gears in my Dana 36 with cheater slicks, still managed a 12.77 with a 1.7 60 ft.
I cut the stock towers completely off,,,,, and bought some 1018 CRS, 1/4" thick and made my own towers,, I'll post pics next weekend when they are welded on.
The 85 stock towers are not even close to a QA1 coil, which is 3.563 wide. My new towers will be thicker than the 1996 steel towers that are 5/32" thick.
Old Nov 18, 2007 | 07:47 AM
  #42
Mojave's Avatar
Mojave
Very interesting read. I am considering putting coil overs on my 96. I am currently running the 115.5 Z51 spring (659 lbs/in), and I want to up the spring rate some, but I'm unsure of just how much spring rate I will need to not only match the Z51 spec, but increase it some as well.
Old Nov 18, 2007 | 08:46 AM
  #43
STEVEN13's Avatar
STEVEN13
Great infomation!
Old Nov 18, 2007 | 03:50 PM
  #44
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I'm going with dual rate coil overs
http://forums.corvetteforum.com/show...hlight=hardbar
This allows for both a nice ride and good performance.
Old Nov 19, 2007 | 11:05 AM
  #45
rickneworleansla's Avatar
rickneworleansla
To have dual rate coil overs do you need special shocks? Will the coils work with most shocks? QA1 adjustables?
Old Nov 19, 2007 | 11:29 AM
  #46
BrianCunningham
Gary's the best to answer that question.
I sent a link to this thread.
