1986 L98; I believe I have a bad fuel return check valve. Is this known as the "pulsator" in the FSM? If so, I need to replace the entire fuel pump, right? That would be odd since it was a new pump about 15k miles ago...
What driveability issues should one expect with a bad check valve?
Good question; I don't know if the check valve is inside the pump or in the pulsator and neither my FSM nor the pump instructions (did this job two days ago) clarify the issue.
For one you may not have good fuel rail prime if pressure bleeds down too fast after you turn On the ignition, though I don't know if it would be a real issue in startups.
Also you could monitor fuel pressure to see if it's at all unsteady. To do this unplug the vac line and plug it at the plenum fitting. Then run the RPMs up & down to see if pressure holds; it should be rock solid steady.
However, even a little fluctuation here may not be an observable issue while driving. Remember that fuel flow goes as the SQRT of pressure change so if there is say a 2% pressure "pulsation" there is only a 1% variation in fuel flow capability.
The pulsator is seperate from the pump, the check valve is inside the pump and would require a new pump. You could try taking it apart. If the valve is bad the car would not have much fuel pressure when starting. You could turn the key twice to get the pump to run twice before cranking if there is a long cranking time. Injectors and FPR can leak down to.
Still starts fine but fuel pressure bleeds off immediately after the fuel pump shuts off. I think I've narrowed it down to the check valve as FP doesn't bleed off when I crimp the fuel supply line.
The Pulsator sits on top of the pump, so I believe it could still be either of the two.
The checkvalve is part of the fuel pump and would require you replace the entire fuel pump.
However more than half the C4 have the same "problem" you have. It is not a problem at all as you can attest to as your car starts fine.
Once you turn on the key the fuel pump runs for 3 secs and this represrrurises the injectors. If the circuit for the fuel pump that turns it on for 3 secs goes out you will have to crank the car until the oil preassure pumps up and triggers the other circuit to ground the fuel pump to get fuel to the injectors.
It was the pulse damper on mine that caused my quick pressure drop. It's a slip fit between pump and hard line. 2 clamps and a piece of hose and all was good.
I would do as AGENT86 suggested first. Remove the pulsator and replace it with a hose and clamps. Then recheck the fuel pressure loss. If you have verified that the leak is in the tank, make sure the fuel line connections are good. If it still leaks down after removing the pulsator then the check valve is the suspect. Question is.....is the problem bad enough purchase a new fuel pump?
