Problem found.....but?
Old Mar 25, 2007 | 10:18 PM
R59's Avatar
R59
Default Problem found.....but?
I posted about my 94 hard starting anytime...well found the problem after checking the fuel pressure regulator and found it dumping fuel in the vacume side. Looked at it three times before finding the problem......but now the line is leaking fuel on the outside of the regulator....am I missing something??don't see how to make the fitting stop leaking on the line side?? is there an O ring or something? the clip seems useless but I don't know.... Please any help to install the line back to the regulator??
Old Mar 26, 2007 | 09:03 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If the vac line had fuel in it, your diaphragm is ruptured. Did you replace the diaphragm ??
There should be no fuel at that fitting at any time.
