96 PCM or Opti
Your ground and voltages are good.
You could try another PCM
Ignition key off, remove Ignition Module connector.
Set meter to read AC volts and connect probe to terminal B – white wire. Have some one crank engine, meter reading should be between 1 to 4 volts. If you use a scope it will be about 5 volts. If you don’t get it, you are on the right track probably. If the voltage is there, the ICM could be defective.
The PCMs are pretty reliable (better than ECMs) and would not suspect it as my first choice. You can probe the low and high resolution pulses from the opti but do need to use a scope. Everything must remain connected. I usually slide a pin down along the wire into the connector at the opti. You can then attach the probe to the pin. The low resolution pulse is the important one which is need for engine run, the high is used for timing. Pin A, red/black is low resolution, pin B PPL/wht is high resolution. Pin C Red, is 5 vdc.
If you don’t have the low resolution, the opti probably is the problem. If you have the pulses, look to the PCM. It could be bad or check the connectors on it.
Charge on.
A few weeks ago I had Brian at PCMFORLESS.COM burn a PCM for me. Instead of sending my PCM, which works flawlessly, I opted to spend the extra $$ and have him send me a complete PCM with the new programming in it.
I now have the factory PCM for my 96 LT1 Vette boxed up and Brian's installed in my car. You may have read my posts on how pleased I am with his programming.
If after you've done all the testing you can, and if you cannot find a 96 LT1 Vette PCM locally, I can send you mine to use for testing, just to eliminate the PCM as the possible cause of the problem.
I MUST have it back though. So If you're willing to pay the shipping costs involved in me sending it to you and you returning it to me, let me know and I'll send it.
This is what Forum members do for each other, right? It's about trust.
Jake
To answer your question, all you need to is disconect and unplug yours and plug in mine.
There are two screws and four plugs which are color coded. It's a really simple swap. You won't need to have anything done it mine, no reprogramming or anything like that. Since we both have the same year (96) and model, (LT1) Vettes it may take you all of five minutes to make the switch.
If you want me to ship it to you, I can do it tomorrow. Just email me with your address - jcameron266@sbcglobal.net
Isn't retirement nice? BTW, my son, Ryan, is a first year Cadet at West Point.
Let me know,
Jake
